Old 18th July 2008, 09:20 AM   (permalink)
Originally Posted by transistance View Post
But this is supposed to be implemented into the body of a guitar.. ::cry::
Damn.. I don't even have a fully functional circuit yet and already planning how to implement phantom power...
bummer
hi
You could get a battery holder, for say 'AA' rechargeables, make up the required voltage.
Or get a bigger guitar....
EDIT: read your PM.
The best way is use a DVM , on a current range and measure the actual current taken by the 9V.
You need to know this anyway for the battery question.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 18th July 2008, 09:48 AM   (permalink)
ok.. well, another question what's an easy software for creating PCB's? Something that has most of the IC models in the default library?
transistance is futile...
transistance is offline
Old 18th July 2008, 10:25 AM   (permalink)
A lot of members use Eagle.
http://www.cadsoftusa.com/
free lite version:
http://www.cadsoftusa.com/freeware.htm
Eric
PIC tutorials:
Old 18th July 2008, 10:33 AM   (permalink)
I'm checking it out, it looks a little confusing though.. when you auto-route does it actually know how to connect the power and ground to ICs 'cause in the schematic phase there are no power connection options.
I just sampled with 2 tl074's, when I auto-routed, it automatically connected both IC's grounds and VCCs together but did not connect them to the power supply.
Old 18th July 2008, 10:36 AM   (permalink)
I dont use Eagle.
IIRC 3v0 and atomsoft are into Eagle, they may be your best advisors.
Eric
PIC tutorials:
Old 18th July 2008, 03:36 PM   (permalink)
A 7809 has a supply current of typically 4.3mA or 8mA max.
A TL074 has a supply current of typically 5.6mA or 10mA max.
The total current is next to nothing.
You have something that is shorting the 9V supply.
audioguru is online now
Old 18th July 2008, 03:43 PM   (permalink)
I have not noticed any shorts yet, although it's always a possibility - the filter(9V) side is very chaotic and crowded. I do get a complete circuit beep when I check between the +/- of the 9V rail, but I thought that is probably because of the voltage dividers right? Or i should not get a complete circuit when I test them?
You're most probably right, i shouldn't get a bleeping sound there, right? (considering I'm using 1M resistors there - nothing close to a short circuit value)
Old 18th July 2008, 05:07 PM   (permalink)
hooray!! 20A; i think there's a short...
Old 18th July 2008, 07:12 PM   (permalink)
Default woot!!
Can I get a "woot woot!" for the square wave output?
Now should I feed this into the PIC or should I use LM2907 to convert this to voltage then feed it to PIC's ADC?
btw the wave has 1.1 V amplitude.
Old 18th July 2008, 09:34 PM   (permalink)
Don't use an LM2907 inaccurate tachometer IC to convert frequency to a voltage. Use the micro-controller as an accurate frequency detector and indicator.
The output of the comparator should be 5V p-p not 1.1V.
Old 18th July 2008, 09:43 PM   (permalink)
In the schematic, you need to click the "Invoke" button, then click the IC symbol in question. You will then get a popup asking you to specify the gates you wish to add. Select "Power". This should give you a small symbol representing the Vcc and GND for the part which you can place as you like. Don't worry that it is not visibly connected to the part on the schematic; Eagle knows what is going on and it'll be connected properly in the board editor.
Make sense?
Torben
Curiosity was framed. Ignorance killed the cat.
Torben is offline
Old 21st July 2008, 09:45 AM   (permalink)
Question PIC Basic Pro
Here is the latest version of the filter. As of now my Vpp of output signal is 1.1V . Any ideas as to why? Is there a problem with the design or my actual circuit? Will 1.1Vpp adversely affect my PIC from reading in the frequency?
Can anyone help me out with timer and RTI modules for a PIC controller (I will need RTI for frequency detection, right?) using PIC Basic Pro? I'm using a 16F877 to detect rising edges of my square wave output, start a count with first edge detected and stop on the 5th and reverse the average period to get fundamental frequency.
How do you set the timer and rti modules in PIC Basic? How do you read the timer and rti modules?
Some .bas code examples or pseudo code will be greatly appreciated.
Thanks in advance,
File Type: jpg Fundamental Frequency Square Wave Generator.jpg (80.2 KB, 23 views)
Old 21st July 2008, 10:07 AM   (permalink)
With no signal on the input, what dc voltage level is measured on the output.?
Eric
PIC tutorials:
Old 21st July 2008, 04:14 PM   (permalink)
Floating Input => VDC of Output = 2.54V
Floating Input => VAC of Output = 2.35V
Grounded Input => VDC of Output = 1.54V
Grounded Input => VAC of Output = 0V
Old 21st July 2008, 04:34 PM   (permalink)
The grounded input, giving those output values seems odd.!
Are you sure the system isnt unstable ie; oscillating.?
Is the 1.1Vpk signal you posted earlier superimposed on the 2.54Vdc.?
You should have the Vinput connected, with the Vin set to zero, when you take these measurements...
Remember its a high input impedance opa.
Eric
PIC tutorials:
Audio Frequency Detection transistance Electronic Projects Design/Ideas/Reviews 21 25th June 2008 03:31 PM
Frequency detection Nile_Team Micro Controllers 9 3rd April 2006 12:49 PM
Audio beat detection jrz126 Electronic Projects Design/Ideas/Reviews 21 12th May 2005 12:28 PM
active filter for digital guitar tuner swh General Electronics Chat 6 7th June 2004 06:52 PM
IR detection by band pass filter hasanaziz008 Electronic Projects Design/Ideas/Reviews 1 6th May 2004 03:14 AM
