Old 26th October 2003, 11:00 AM   #1
Default Transformer: What Input/Output?
I have this transformer that I pulled out of a toy light gun. I want to build the stun gun project but I did not know if this transformer was the right size at 1K:200K. Is there a way for me to test it and see what it is?
Thanks,
Kyle
--{Kyle}--
LifeForce4 is offline
Old 26th October 2003, 11:41 AM   #2
Check the Voltage rating 1st.
mysemcon2000 is offline
Old 26th October 2003, 12:02 PM   #3
How do I check it? It has no text on it and there are three wires on one side and two on the other.
Kyle
--{Kyle}--
Old 27th October 2003, 02:08 AM   #4
Default small transfo
1. measure the resistance of the 3 wire side, if its is 1k thats the center tap side and thats where you input the circuit.
2. the two wire side is your output.
3. whats the voltage used in your train
4. this is assuming that you will use this for stun gun circuit :wink:
\"NONE BUT THE BRAVE DESERVES THE FAIR\" ~Shakespeare~
mozikluv is offline
Old 27th October 2003, 04:06 AM   #5
I checked and the two outer wires are 0.4Ohms the middle wire with either outer ones is 192.39.
Only if the resistance is 1K?
That is correct.
Thanks,
Kyle
--{Kyle}--
Old 27th October 2003, 07:01 AM   #6
Default transfo
what you need for a stun gun is 1k for the input and 200k for the output :wink:
mozikluv is offline
Old 27th October 2003, 12:19 PM   #7
Yeah that why I posted this.
http://www.electro-tech-online.com/viewtopic.php?t=4169
Thanks,
Kyle
--{Kyle}--
Old 28th October 2003, 05:03 AM   #8
Transformers do not have input and output. You decide that. They work both ways. You need to discover voltage rating and current rating and turns ratios. The best way to do this is by measuring inductance of windings (although you'll have a 50/50 chance) not resistance. Why? because one side can be rated for much lower current and have a much higher resistance even though the number of turns might be smaller.
And if your transformer gets hot, you might be running the core into saturation. I dont know what a stun gun involves but if it uses high frequencies, you'll need a core that can handle it without running into saturation. If your project doesnt work at first and if the transformer feels warm, check this.
Optikon is offline
Old 28th October 2003, 04:44 PM   #9
Check what? I am a little lost. So I can use any one of the three transformers that I have on my other post? If so then I dont need to check this one.
Thanks,
Kyle
--{Kyle}--
