Old 7th July 2008, 10:11 AM   (permalink)
Default Simple Relay timer
Hi all,
I need a circuit that will operate a relay for aprox 10 seconds when power (12V) has been applied. After the 10 seconds the relay should switch back. Power will contine to be applied, but the relay shouldn't switch over again, until the power has been disconected & reconected again.
I know this should should be a simple circuit, but I can't seem to get the relay to switch over for 10 seconds. I was trying to avoid a 555 circuit, so I can make this on a strip board.
This is to fix a problem with my car.
I'm currently using a switch everytime I start the car, which disconnects the coolent sensor, then start as normal, before toggling the switch again to reconnect the sensor.
Any help would be greatly apreciated.
craigey1 is offline
Old 7th July 2008, 10:18 AM   (permalink)
Originally Posted by craigey1 View Post
Hi all,
I don't see your problem?, 555's are perfect for stripboard, and an obvious simple solution to your problem.
Old 7th July 2008, 10:32 AM   (permalink)
It was more of a case of it being a long time since I've done any circuit design. I know 555's are fairly straight forward, but I can't remember how to work out the time delays etc. I thought it would be easier to use a resistor & capacitor to create the delay.
craigey1 is offline
Old 7th July 2008, 10:38 AM   (permalink)
Ya 10SEC delay is fair with 555 IC.Basic monostable arrangement will do the job.
To calculate the resistor & cap values.
Info about MiscEl
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is online now
Old 7th July 2008, 11:44 AM   (permalink)
I think the problem you're having is that you want the relay to turn on when the circuit is powered, then turn off after 10s. Normally a 555 requires a trigger pulse but this can be disabled and the whole IC can be used as a schmitt trigger.
For about 10s R should be 1M and C should be 10µF
The only problem with this circuit is, it needs to be off for awhile to discharge the capacitor but there's no way to avoid this.
555 Timer/Oscillator Tutorial
Screen name: Aloone_Jonez
Hero999 is offline
Old 7th July 2008, 12:10 PM   (permalink)
That's great. I see what you mean about having to wait for the capacitor to discharge before the circuit can be reused, but this shouldn't be a problem for what I need.
Once the car is started the coolant sensor can be connected again & the car runs fine. It only needs to be disconnected when the car is started from a cold (several hours since last being used) start. If I stalled etc, the engine would still be warm enough to not need the coolant sensor to be disconected.
Thanks for all the replies.
craigey1 is offline
Old 7th July 2008, 12:35 PM   (permalink)
Default Just hook the 555 to coolant sensor
If car is cold the 555 triggers for 10 seconds.
If warm the 555 is disabled.
or go the other way. Have the coolant pump or fan off , start the car then the coolant fan comes on after the engine is running for 10 seconds regardless if engine is hot or cold. 10 seconds is minor. Might be easier.
The 555 is triggered off the ignition system. I would put a 30 second delay so engine is actually running.
Sounds like your coolant fan is preventing the engine from starting?
If so they do make a temp switch for the coolant fan that only turns it on when needed.
MrDEB is offline
Old 7th July 2008, 12:52 PM   (permalink)
It's not a problem with the coolant or fan. I'll explain..
The car is a diesel & for some reason if it has been sat for several hours or overnight, the car will take aprox 30 - 45 seconds of turning the engine before the car finally starts. I spoke to the dealer & they told me the problem was the fuel pump & wanted £1800 for the part + fitting.
I posted on a forum which specialises in these cars & someone suggesting trying to unplug the coolant sensor, as this forces the car to think the outside temperature is cold, so it turns on the glow plugs. (Most modernish cars don't use the glowplugs unless it's very cold & instead rely on the engine compression to start). After a few seconds the glow plugs turn off & the car can be started, the engine then kicks into life immediately.
The person on the forum suggested wiring the sensor to a switch in the car, but I thought there had to be a better way to do it!
I hope that makes sense & explains what I'm trying to achieve. Hero999's circuit should do the job.
craigey1 is offline
Old 7th July 2008, 01:35 PM   (permalink)
That's not true.
A diode across the resistor will help to speed up the discharge, when the power is removed the capacitor will discharge through the 555 and the other resistances in the circuit. This is likely to happen very quickly as the 555 draws quite a bit of current. Choose a diode with a low enough leakage so it doens't interfere with the operation of the circuit - use a small signal silicone diode rather than a power rectifier and don't use a Schottky because the leakage will be far too high.
Hero999 is offline
Old 7th July 2008, 04:14 PM   (permalink)
That's great. Thanks
craigey1 is offline
Old 7th July 2008, 10:27 PM   (permalink)
Default Have you tried unhooking
the coolant temp sensor and see if the car starts?
MrDEB is offline
Old 8th July 2008, 09:11 AM   (permalink)
That's what the circuit will be doing. (disconnecting & reconnecting the sensor). I have unhooked the sensor, that's when the car starts normally.
craigey1 is offline
Old 8th July 2008, 10:23 AM   (permalink)
Have you looked in Maplin Craigey? I think they do a kit that will do this for under £10
jimmythefool is offline
Old 8th July 2008, 10:42 AM   (permalink)
Thanks, will have a look at their site later today.
craigey1 is offline
Old 14th July 2008, 07:22 PM   (permalink)
thanks alot
Hamoudy is offline
555 timer astable/relay firealarmfrea785 Electronic Projects Design/Ideas/Reviews 0 24th May 2008 03:28 AM
Relay and timer TCDK Electronic Projects Design/Ideas/Reviews 9 21st April 2008 05:11 PM
Help needed in Relay/timer circuit woodrufj Electronic Projects Design/Ideas/Reviews 15 27th June 2004 06:43 AM
Looking for a DPST relay with 15-minute timer vandy33 Electronic Projects Design/Ideas/Reviews 6 2nd February 2004 11:15 PM
555 timer with a relay crchisholm Electronic Projects Design/Ideas/Reviews 3 30th June 2003 09:25 PM
