Old 7th July 2008, 03:33 AM   (permalink)
Default Multiple logic IC
Are there any chips out there that have all the following on 1 chip?
AND gate
NAND gate
2 AND gates with inverted inputs.
The reason I ask is I need to free up a couple of pins on my PIC chip. I am currently outputing 4 different values on 4 pins. What I want to do is output the 4 different values on 2 pins and use these gates to get the 4 results...i.e.
0 + 0 = 1
0 + 1 = 2
1 + 0 = 3
1 + 1 = 4
NAND is the first, AND with 2nd inverted input is second, AND with first inverted input is third, and AND is fourth.
I suppose I could do it with 2 NOT gates and 4 AND gates.
Cheers,
Craig
richacm is offline
Old 7th July 2008, 03:39 AM   (permalink)
Funny you should ask...
http://www.electro-tech-online.com/g...es-one-ic.html
Mikebits is offline
Old 7th July 2008, 03:49 AM   (permalink)
Quite interesting but I would probably still need a few of these to do the job I want. I would rather do it with 1 extra chip.
richacm is offline
Old 7th July 2008, 03:53 AM   (permalink)
Then perhaps.
http://www.ee.ctu.edu.tw/material/da...et/16v8mil.pdf
Mikebits is offline
Old 7th July 2008, 04:04 AM   (permalink)
Now thats a pretty nice chip! Bit of an over kill for what I'm doing though - it kinds of also leads to the point of why not just by another cheap as PIC chip and program that.
What I am going to do though is remove 6 other pins I used for a 8bit wide bus and instead use a shift register to store this. I will then only need 2 pins to do this.
Thanks for the info though.
richacm is offline
@Mike: I have not seen any PAL's or GALs for a long time. My HS uses them, but I am going to persuade the teachers and the school board to stop using GALs, as they are completely left behind as compared to microcontrollers.
I would go for the 74xx08 and the 74xx04, as it is small and not a GAL, as then you would have to get a programmer, etc.
Krumlink is offline
Old 7th July 2008, 04:18 AM   (permalink)
An ISP Gal device eliminates the need for any fancy programmer. Only a PC is needed.
I would like to hear the response you get after making this proposal.
Mikebits is offline
Old 7th July 2008, 05:03 AM   (permalink)
Looks like a 74HC238 might do the trick for you:
http://focus.ti.com/lit/ds/symlink/cd74hc138.pdf
kchriste is offline
Old 7th July 2008, 05:10 AM   (permalink)
0 + 0 = 1
0 + 1 = 2
1 + 0 = 3
1 + 1 = 4
Heck, that would work. Nice
Mikebits is offline
Old 7th July 2008, 05:17 AM   (permalink)
Its middle of summer vacation, so I have some time to wait
Krumlink is offline
Old 7th July 2008, 05:46 AM   (permalink)
you beat me to it. I just saw the demux chips. I'm going to use the HCF4028 instead though as I want High states.
Cheers,
Craig
richacm is offline
Old 7th July 2008, 10:25 AM   (permalink)
That's equivalent to a NOR gate, it sounds like you haven't tried to use boolean algebra to simplify your expression.
Screen name: Aloone_Jonez
Hero999 is offline
Old 8th July 2008, 01:19 AM   (permalink)
If you use a shift register such as:-
http://www.fairchildsemi.com/ds/74/74VHC164.pdf
you can output basically independently on as many outputs you want, using two pins on the PIC. There is some more code to be written and the outputs will go to the wrong state briefly while all the outputs are changing.
Diver300 is offline
Old 8th July 2008, 03:15 AM   (permalink)
Cheers,
Craig
The 74HC238 will give you active high outputs. The 74HC138 will give active low outputs. The HCF4028 is also a good choice. Have fun.
kchriste is offline
multiple sounds from a pc Gaston Chit-Chat 39 25th January 2008 07:37 PM
multiple regulators, 1 pot technogeek Electronic Projects Design/Ideas/Reviews 10 17th June 2007 02:32 AM
Help with multiple switching nickname Electronic Projects Design/Ideas/Reviews 11 14th August 2005 03:22 AM
Multiple PWM using PICBasic or C need help!!! picBasic_Freak Micro Controllers 6 1st March 2004 07:36 AM
Multiple LED flashlight? LifeForce4 Electronic Projects Design/Ideas/Reviews 3 22nd September 2003 06:43 PM
