| I was watching a History channel documentary on Nazi technology, and they talked about the V1 flying bomb being the first weapon to use INS based on gyroscopes, and how amazingly accurate they were for something of their time being able to fly to Britain from Germany and hit cities with some decent accuracy. Anyway, with todays MEMS products, would it be possible to make an INS for an RC helicopter, RC airplane, or model rocket (I imagine that would be most difficult)? I know that GPS would be a much more modern and accurate method for accomplishing the same thing, but I have something of an interest in just doing things 'the old way' for personal edification. Any recommendations on where to start? I won't be loading these with warheads or anything, though I might try and target a friend's farm or something to test my accuracy. | |
| It is possible I guess. It is difficult, however, to use gyros and accelerometers (and anything realy that requires mathematical integration) for absolute navigation. So acceleration to determine absolute distance travelled is almost completely out the window since you need double integration (almost regardless of how well you can calibrate them). With gyros you might be able to pull it off with calibration. It's difficult though. If you want to see the accuracy of an affordable calibrated unit from Microstrain, check out these videos: The Journey Robot - David P. Anderson They don't exactly give you a sense of the accuracy of the gyros though since it is a ground vehicle that is also fusing double integrated acceleration with odometry. But you get the idea of the accuracy. Analog Devices also now has calibrated 6-axis gyro+accelerometer units for about $700. ADIS16350 ADIS16354 ADIS16355 For all intents and purposes the 54 and 55 are your better bets since the 50 is onyl calibrated at room temperature while the others are calibrated across temperature ranges. THe best gyros I have found are those from Silicon SEnsing which run about $150 each per axis. They aren't calibrated but have very good uncalibrated specs that you might get away with certain absolute positioning applications with some creativity. By far, the easier applications are those where there is a periodic "resetting" of the integrated values to correct the bias offset that will occur for the gyros- like a compass for the heading and infrared horizon sensors for the roll and yaw (Melexis MLX90614 is the best one I've found with the digital interface. It's also calibrated. I don't know how well raw analog thermopiles are matched since they must work in pairs, but I couldn't figure it out so decided on these digital ones instead). http://www.uavs.net/horizon_sensing_autopilot.pdf From my research, I've drawn my own conclusion that it isn't possible to do dead reckoning with accelerometers without some kind of external absolute positioning like GPS to make the unbounded error bounded. Orientation (with gyros) is much easier to deal with, but in "absolute orientation" schemes you would still need IR horizon sensors and compasses. Two of the biggest problems with acceleration odometry are the double integration and how the distance vector is dependent on the gyro readings. So the acceleration odometry is built on top of the gyros (and all their errors). Last edited by dknguyen; 5th July 2008 at 05:46 PM. | |
Im afraid that program misinformed you, the V1 flying bomb 'buzz bomb' had no INS navigation. It was launched from ramps pointed towards London from France and Holland, it hadnt got the range to fly from Germany. It had onboard a propeller driven veeder counter which measured the distance flown, the fuel line was cut at a predetermined count and the engine cut. The INS system was first used in the V2 in 1944, again it was launched from France and Holland, not Germany. I was only 12 years old at the time, but I do remember, when the engine stopped on a V1 you got under cover. No such luxury with V2, no whooshing sound until after the bang. Regards EDIT: inertialnavigation The V1 Rocket world war 2
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 5th July 2008 at 05:47 PM. | ||
| I'll quickly outline the the various layers of an IMU and how each one is built on the other, and how far you have to go for particular applications. Layer 1: 3-axis Gyro + integration for each independent axis Application: Dampening and stabilization of the vehicle response, in the presence of a pilot, it can be used to lock the vehicle in it's current orientation when the controls are released for short times. Over time drift will occur, but the pilot is there to correct for that and usually controls aren't released for a very long time either so drift is not a big problem. Layer 2: 3-axis Gyro + integration foe each independent axis + integration of the collective angular readings Application: Allows you to keep track of where the ground is. Without high quality gyros, external absolute reference sensors such as horizon sensors and compassesm or a pilot unbounded error will occur flipping the vehicle over time. The math starts to get tricky as you need to convert the pitch/roll/yaw angular readings on the plane to a coordinate system relative to the ground (which itself is built up on previous successive math operations of the same kind) in order to keep track of where the ground is. Layer 3: 3-axis Gyro + integration foe each independent axis + integration of the collective angular readings + acceleration Application: Dead Reckoning. Now you also need to use the acceleration readings double integrated built on top of the results of the tricky math from Layer 2 to figure out the distance and direction travelled between samples. Unbounded errors run abound! Best to have some kind of reference system to bound the error just like the gyros. GPS is about the only one I can think of for bounding positional errors short of terrain mapping + radar scanning. In my projects I've all but abandoned Layer 3. Layer 1 and 2 are quite possible though. Last edited by dknguyen; 5th July 2008 at 05:58 PM. | |
| I recall a documentary saying the V1 was such a terrifying weapon because it could not be aimed accurately. You could not avoid it by staying away from "high value targets". It was just as likely to land on a house as an airplane factory.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |
When the allies pushed the Germans back after 'D day' they started aiming for targets in Belgium and Holland.
| Perhaps I got the V1 and V2 confused. It has been a while since I saw the documentary, but the project has been in the back of my mind since. | |
The gyro in the V1 was used to keep the wings level in flight. Allied pilots used to fly wing tip to wing tip with the V1 in order to distrupt the air flow over the wing, made it tilt the V1 so that the gyro went unstable and the V1 flipped over and went down. Some pilots actually pushed the damned things over with their wing tip.!
| hi, Do you mean shoot down instead of tipping.? Have you seen the newsreels of what happens when the V1 blows up in mid air. The prop driven planes were only fast enough to intercept the V1 if the plane was head on or made a diving approach in order to match the V1's speed. The later Meteor jets could match their speed. Triple A or ack ack did shoot down a lot of V1's IIRC about 5 or 6000 were launched against the UK.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 6th July 2008 at 08:20 AM. | |
Peenemünde - Wikipedia, the free encyclopedia But V1's weren't launched from there, they didn't have the range. | ||
BTW, the V1 never had a fuel shut off valve. The fuel was calculated for a certain range and when the engine quit that thing descended unaimed. Hans | ||
When I say launched against the UK, I dont mean tested at "Peenemünde", which is of course on the Baltic coast. One of my best friends was in the Luftwaffe during the war. I have been to Germany on business many times. Regards. PS: I dont agree regarding the fuel cut off, but I will re-examine my data.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 6th July 2008 at 06:34 PM. | ||
| Robot Navigation | K-Dog | Robotics Chat | 5 | 11th March 2008 09:29 PM |
| navigation beacons | arod | Robotics Chat | 18 | 9th December 2007 08:57 PM |
| Help! To choose the good GPS Navigation System | nickkanny | General Electronics Chat | 2 | 16th November 2007 08:14 PM |
| robot navigation | AllanBertelsen | Robotics Chat | 38 | 30th May 2007 04:15 PM |
| Robot Navigation | crazymonkey | Robotics Chat | 8 | 9th March 2004 04:21 PM |
