I have a PIC chip that I want to output a digital signal from (easy). However the component that receives this signal has a 3V max on it. How do you normally go about reducing the voltage on the line? Should I put 3 diodes (1N914) in series on the line to drop the voltage by 2.1V? Thanks, Craig |
You can do many things:
-diodes -resitive dividers -level translation ICs -comparators -op amps -pull-down transistor with a pull-up resistor -resistor with zener diode -resistor with positive rail clamp diode http://www.newark.com/pdfs/techartic...ricksBrchr.pdf
NO, that picture isn't me so don't bother asking if we can be friends. Last edited by dknguyen; 4th July 2008 at 01:55 AM. |
What a great link. Thanks!
You really need to give more details of EXACTLY what you're trying to feed, that makes a huge difference - but your diodes suggetsion is probably the worst possible idea.
Have a look here: http://www.sparkfun.com/datasheets/S..._datasheet.pdf on page 17 for a circuit using the 74HCT08, Ive used it on RS232 and SPI signal lines without problems.
You could use a HEF4050 non inv CMOS buffer, will tolerate input voltages higher than Vcc.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
I agree with eric, but a different chip. Use a 74AC245 supplied with 3VDC. It is a non inverting buffer that takes the 5VDC input and outputs the 3VDC signal, creating a effective level converter. the 245 can sink/source up to 50ma in some cases and can be supplied from 2VDC to 6VDC, but in your case use 3VDC.
The LVC logic family can operate at 3v and tolerate 5Vin. |
hmm I wonder why I said AC, maybe because its what I have on hand, sorry about that.
They both have a C in them, easy mistake
there are many approaches for logic level translation, one of the simplest is to use open-collector (or open drain respectively - LS,HCT...) logic - gates, inverters, buffers (e.g. 74xx03,74xx05,74xx07 ...) - for low speed logic it is ok, just connect the pull-up resistors to the voltage you want for Vh (3.3 or 5V) for the output. Another approach is to use specialized ICs, for example from MAXIM: (MAX337x, MAX339x) MAX3372E, MAX3373E, MAX3374E, MAX3375E, MAX3376E, MAX3377E, MAX3378E, MAX3379E, MAX3390E, MAX3391E, MAX3392E, MAX3393E ±15kV ESD-Protected, 1µA, 16Mbps, Dual/Quad Low-Voltage Level Translators in UCSP or there is a chip from TI: (SN74LVC2425) Octal Bus Transceiver And 3.3-V To 5-V Shifter With 3-State Outputs - SN74LVC4245A - TI Product Folder just an example, there are more possibilities to implement the level translator STMicroelectronics - Level Translators Petr |
Petrv, it has already been covered! thank you for the extra info but I think the OP has figured it out hopefully
I know I just wanted to point out the additional possibilities. By having more choices it is possible to select the solution most suitable for the original problem
And perhaps it can help someone else who is dealing with a similar problem as logic level translation is a common issue, especially between 5V and 3.3V logic. Petr |
This is one of the best 5V-3V docs I found so far: http://www.microchip.com/stellent/gr...c/en026368.pdf
| Digital Pot Help | fiveten | General Electronics Chat | 10 | 12th December 2005 04:59 AM |
| Digitial wildlife surveillance camera | mkohr | Electronic Projects Design/Ideas/Reviews | 0 | 29th January 2004 11:23 AM |
| Digital | krishtriram | General Electronics Chat | 2 | 26th August 2003 10:28 AM |
| Need help, new to digital | Chris_F | General Electronics Chat | 2 | 28th July 2003 05:21 PM |
| digital to analog - analog to digital converters for sale | spencer | General Electronics Chat | 2 | 15th May 2003 07:17 AM |
