IC3 in the reciever is a 78L12, 12V regulator, which requires a minimum of 14.5V to work. This regulator will need to be replaced with a 12V low dropout regulator. Alternately the circuit could probably be modified to work with a lower voltage regulator such as a 78L09, 9V device.
__________________ Carl | ||
I think what ika is asking is, how to modify the circuit to enable data transmission via the vehicle wiring rather than the local mains supply.? Regards
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 1st July 2008 at 06:36 PM. | ||
The signal transformers L1, shown connected to the AC, instead would be connected to 12V power through the cap and to ground (the ground side doesn't need a cap). I assumed that was sort of obvious but I guess it is not. This scheme may not work as well in a car as with a power line since a power line has balanced wires for the signal and return path. The car has one wire and a chassis return which may muck of the signal some. Only way to know is to try it.
If it was my project, I would get a car battery on the bench, make up that matching transformer/drive and drive it with a signal generator. See at which frequencies, if any, the battery offers the highest impedance to the 'ac' test signal. I think the problem on a car is all that electrical noise from the different systems.
| | (permalink) | ||
Compare this to the 12V DC bus of a car where most of the electronics have a capacitor across the DC input which presents a low impedance path to ground for any carrier you try to superimpose. As I alluded to, and dknguyen stated, the best way is something like this:
__________________ --- The days of the digital watch are numbered. --- | |||
can you tell me what are those triangles in your schematic? are those buffers...? i don't quite understand the part where 12VDC is mixed with data.. Also shoudnt we use a High pass filter instead of the LPF? thx again. | ||
But I don't understand how the circuit you propose will get around this problem since it's outputing a signal at some frequency, which will also be suppressed by the caps.
__________________ Carl Last edited by crutschow; 1st July 2008 at 10:26 PM. | ||
| | (permalink) | ||
If you wanted to make this data path bidirectional, the circuitry would be somewhat different. Quote:
__________________ --- The days of the digital watch are numbered. --- Last edited by kchriste; 1st July 2008 at 11:05 PM. | |||
Thanks a lot for your insight... i think i'll give it a try. at least to learn! Can i ask you one more favor: Where does the battery's 12V wire goes in your circuit? Can you pin point the node that is to be connected to the 12V line? thanks a lot. | ||
| Hello again.. I want/need to make some tests, and see with the scope how a car electrical system responds. I just dont have a clue on "how to inject data into DC" i understand the principle, but i can't figure out how to make that work with the components that i know : coil, cap, BJT, resistor, etc...? can anyone give me hand on that? | |
| If there was a simple / cheap effective solution to send data through a vehicles 12V DC wiring then why would cars still use CAN bus? | |
| | (permalink) | ||
Basically, you would use chokes/inductors to separate the signal from the rest of the system and capacitors to couple into this "isolated" piece of line. The trick is to use chokes that can handle the DC current without saturating:
| Seek out the datasheet for the Maxim IC 455, the application notes pdf has a complete circuit diagram. The chip is just a video amplifier and switching, but the application notes show how to send and recieve both DC power and control signals over a "single" wire.
__________________ It may seem like a good idea at the time , but never stir your cold coffee with a soldering iron. | |
| Are you trying to re-invent the ancient BSR X-10 modules? Transmitting AC signals onto a noisy automotive DC power line is futile. The separate wire is the best approach. Wireless could also be tried, it is unaffected by high frequencies under the hood. | |
| If the wheel had not been re-invented then they would still be made of wood! As for the 'futility' of getting data over a noisy DC line the problems are not beyond a solution, indeed if anything many real world examples of 'fly-by-wire' can be found not only in aviation but automotive applications. Closer to home some manufactures of traffic control systems, both temporary systems used during road works and permanent installations communicate both sensor and control data over the DC power line. If you think an automotive DC power line is a bit 'Rough' the you should see what the output of a beat up generator looks like Sticking with in-car applications a quick search of the web reveals a nifty idea to use the DC power line to inter-connect the various elements of 'ICE' (In Car Entertainment) no rolls of wire for the speakers or getting under the dashboard to run the control head cable back to the CD changer in the trunk. Just put the hardware where you want it and find a live wire.
| DS18s20 data line reset | nickelflippr | General Electronics Chat | 2 | 6th January 2008 08:22 PM |
| Need suggestions for reading/writing data serially with a clock line | toodles | Micro Controllers | 3 | 23rd April 2007 10:12 AM |
| FM over AC power line | DJ_ReL@X! | Electronic Projects Design/Ideas/Reviews | 5 | 23rd October 2004 07:35 PM |
| stealing power from Midi Data line | rbairos | General Electronics Chat | 3 | 18th June 2004 12:59 AM |
| getting codes from ADC then transfering to rams | melvinyuen | Electronic Projects Design/Ideas/Reviews | 3 | 24th March 2004 11:55 AM |
