Old 25th June 2008, 07:03 PM   (permalink)
Default Using a transistor to dim a dc bulb
Can someone help me construct a circuit to dim a filiment lamp (9Vdc) using a transistor?
The bulb draws 38mA when connected to 9Vdc, so its a 0.34W bulb.
I have attached my circuit. The lamp can be shorted out by a push switch (this is a door bell push switch with intergrated lamp), so R22 (50 ohms) limits the current in the circuit to 160mA during a button press.
How do i calculate the value for the variable resistor? Is this curcuit correct?
When the button is pressed, Q6 should turn off, hence the micro detects the button press?
kybert is offline
Old 25th June 2008, 11:13 PM   (permalink)
The circuit will not work well since it operates by starving the base current and depends upon the gain of Q5 to determine the operating point. This makes it rather temperature sensitive.
A better way is to remove pot R23 point E from Q5's base and connect point E to ground. Then remove the wiper of the pot from point A and connect to Q5's base. For current limit at the pot extremes, add a 10khm: resistor in series with the pot wiper and Q5's base. (You don't show the value of R23 but good values are 5Khm: to 50Khm:.)
Your notation for Q6's collector output is reversed. When the button is pressed Q6's collector output will be high.
Carl
crutschow is offline
Old 28th June 2008, 07:48 PM   (permalink)
pray why MUST the lamp be shorted when the button is pressed ?
my site:www.simons-photography.com
http://rushdenrotaract.org.uk
Thunderchild is offline
Old 29th June 2008, 09:29 AM   (permalink)
Becuase its a door bell press button, and the lamp is built into the button.
Ive decided not to dim the lamp, just limit the current with a 51R 2W resistor, so much easier!
kybert is offline
Old 29th June 2008, 09:50 AM   (permalink)
ok i gotcha yes thats the best Idea, usually the bel provides so current for the light and when the switch us pressed it shorts the bulb and gives full power to the bell so that it actuallt rings
Old 12th July 2008, 06:17 AM   (permalink)
A MOSFET as an oscillator, with a CdS photocell in the circuit, can be used to automatically dim the LED, if you insist upon using a transistor. Is the LED in the doorbell switch cover, or a part of the switch?
shokjok is offline
Old 13th July 2008, 03:21 AM   (permalink)
Where did you find an LED? The OP is using a common doorbell switch with a 9V, 38mA filament (incandescent) lamp.
mneary is offline
variac and light bulb Gaston General Electronics Chat 7 22nd February 2008 08:29 PM
running incandescent bulb on DC Thunderchild General Electronics Chat 18 26th June 2007 08:33 PM
'Ramping' on an LED or bulb NewcastleSAR Electronic Projects Design/Ideas/Reviews 14 7th July 2006 04:13 AM
Electric bulb inductance. lord loh. General Electronics Chat 2 5th May 2005 09:50 PM
light bulb to LED!? dug Electronic Projects Design/Ideas/Reviews 2 24th August 2004 03:17 PM
