Hello all, I would like to make a very simple and preferably small transmitter on perfboard/prototype board (I do not have the materials to make PCB's). Now while most of the circuits I find online are for FM transmitters, I am open to any other methods of tracking that you guys might have. For the FM transmitters, I found this to be the coolest/easiest one since it does not require a pcb: 1.5 Volt Tracking Transmitter . However, the LM3909 is discontinued. Can a 555 IC perform the same operation as that LM3909? Any ideas will be helpful, but remember, I want simple, non-pcb, and somewhat small. Thank you. Edit: Also, if there is a way to minimize the error in making a hand made inductor out of wire that would be great. By this I mean, I would prefer to have a variable inductor that I can just put a screwdriver to (like a potentiometer) and modify it's value to get the desired frequency Last edited by hugoender; 24th June 2008 at 04:34 PM. | |
The very old LM3909 IC doubles the 1.5V to 3.0V for the transmitter to operate. A 555 IC has a minimum supply voltage of 4.5V. Try using a 6V battery and a 555 turning the transmitter on and off. The transmitter uses a trimmer capacitor for tuning. It is adjusted with a plastic screwdriver.
__________________ IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S | |
| | #4 | |
| | #5 | |
This IC is from Texas Instruments and can operate at as low as 2VDC. I cannot seem to find how much current it can source/sink at 2VDC from the datasheet. It says it can sink over 100mA and source over 10mA but those are probably not the numbers for a Vdd of 2V. If someone can tell me where on the datasheet this information is found (and what they call it) I would greatly appreciate it. If the TLC555 still cannot provide the current needed, is there another IC that does what the LM3909 does (double the voltage)? I don't mind operating a 555 on 6V but if I don't have to then I'd prefer not to (to minimize size). Thank you guys for your responses. | ||
| | #6 |
I looked on the datasheet for the LMC555 that spec's only with a 5V and higher supply. The datasheet for the TLC555 has spec's for a 2V supply and the output voltage drops to only 1.5V when its load current is only 300uA which is next to nothing. The transmitter needs much more current. I think the range of the transmitter depends on its supply voltage. With a 2V supply its range might be across the street (30m). With a 6V supply it might be 200m. with a 5V supply it might be 400m.
| | #7 |
why does 5 V give more range than 6 V ? I think you got your figure switched remember hugo that as distance doubles the power will be quartered when its three times the distance the power will be 1/9
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) www.simonsphotography.org.uk/ - My other hobby www.rushdenrotaract.org.uk/ - make a difference and have fun ! Never buy "Trust" products, all mine broke !!! | |
| | #8 |
| Where did you see 300uA? Could you please let me know what page and what area of the page you are getting this from because I cannot seem to find it. Is it the Idd (supply current) that tells you how much current it outputs? If so... the data sheet says 250uA at 25degrees and 400uA for full range (these are max values).
| | #9 | ||
| | #10 |
| Sorry. I punched 5V instead of 9V.
__________________ Uncle $crooge Last edited by audioguru; 24th June 2008 at 10:52 PM. | |
| | #11 |
There are several tables given on the data sheet. One table list test conditions @Vdd = 2 volts. the other tables 5v etc.
| | #12 |
| Yeah, I guess my question is which value on that table is the current that is present at the output of the IC (how much current does it source/sink)? Or does it always source 10mA and sink 100mA as long as the voltage source is between 2-15VDC?
| | #13 |
On the page with the spec's for a 2V supply, it lists the Output Voltage with 300uA sourcing current (output high). The output current from a Cmos IC depends on its supply voltage. The output low current with a 15V supply is a minimum of 100ma with a max allowed current of 150mA. The output high current with a 15V supply is at least 10mA with a max allowed current of 15mA. The 2V page shows the minimum output high current of 300uA. Didn't I repeat this on another website?
| | #14 | |
| | #15 | |
Yes, it is a simple data sheet, and it is easy to read numbers, I would just rather have someone tell me exactly which value on the table corresponds to the current source/sink of the IC instead of just going with what I think is the correct value and not being sure. If you solve a problem and you think the answer you got is correct when indeed it is not, then all you have done is learned the wrong way of solving that problem. Besides, having a degree has nothing to do with how much you know or how smart you are. It only decides how much you are going to get paid | ||
| bug, tracking, transmitter |
| 1.5 Volt Tracking Transmitter | ElectroMaster | Electronic Projects | 148 | 30th April 2009 08:32 PM |
| Tracking help | ashfsk | Electronic Projects Design/Ideas/Reviews | 1 | 12th March 2007 01:41 PM |
| Tracking transmitter, small but grunty | Gaskell | Electronic Projects Design/Ideas/Reviews | 15 | 24th January 2007 09:16 PM |
| Using LEDs to show the direction of a tracking transmitter | Electric Rain | Electronic Projects Design/Ideas/Reviews | 1 | 18th June 2004 12:09 PM |
| Tracking Transmitter/FM Radio Receiver | RonL | Electronic Projects Design/Ideas/Reviews | 2 | 28th August 2003 08:36 PM |
