Ok, I've got a problem with this circuit again. A member on here helped me the first time I had a problem and it was solved, but now there's a new problem.
When I press the reload button that connects pin1 of IC5 to ground, it loads the input value of 60. However, instead of holding that value and counting down from 60, it imediately jumps to random numbers and then to either 99 or 88. From there the count down function doesn't work. HOWEVER, if the count down is initiated before the counter lands on 99 or 88, it will count down to 00 just fine like it's suppose to. Pressing the reload button to 60 causes it to jump randomly again. Any ideas? ![]() |
You might need to debounce your switch. First you get bounce when you press the switch, then more bounce when you move your finger off the switch.
Check this link, your best bet is the RC solution, the other is adding a chip. http://www.ganssle.com/debouncing.pdf |
Alright, I modified it as such. It still does it. That was,actually, my first thought, because I know the switching circuit is very sensitive. It seems that the two 74HC192's are having errors holding the input value of 60. When I press the reload switch, it loads the 60, but then it jumps to either 99 or 88, and it's always one or the other.
I have another circuit similiar to this, but it's input value is 32. Also, I modified the wiring on the first gate of the 74HC20. In my other circuit, pins 12 and 10 are each pulled high through a gate from 74HC14. Logically, I would think it could work either way. Am I wrong in the assumption? Could the way I have it wired now be causing a problem? ![]() |
Your debounce circuit needs to be built as shown in the link I provided.
![]() You can work out the RC values as shown in the equations, also in link. Also, there is no need for the extra inverter. |
Your sw1 is not debounced
Also your 4 leds in parelle need a resistor. As your schematic indicates the Leds are pulling 28 amps as simulated using TINA. This alone would rattle the power supply and cause all kinds of weird happenings A 150 ohm resistor should bring it down to 23ma. I would opt for a 200 ohm = 17ma |
MrDEB is right, you need a current limiting resistor for each LED segment not one common one. 170 would be about right. You'll also need 0.1uf decoupling caps on every IC.
Alright, here's what I've got. I haven't made these adjustments yet, but I will if ya'll think they look about right.
![]() Last edited by GOkussj5okazu; 26th June 2008 at 04:32 AM. |
Come on and give LEDs 1 through 4 also an individual current limiting resistor.
They like it. |
If you use a 2 watt or even a 1 watt resistor you don't need more than 1.
did adding the resistor, adding a switch de bounce, adding caps to supply/ground help?? |
Yes, your debounce looks correct. Just calc the right values. I don't think you need R5 anymore.
| Count Down Timer | RetiredHAL | Electronic Projects Design/Ideas/Reviews | 8 | 8th March 2008 03:36 PM |
| count down timer | nader hoseini | Electronic Projects Design/Ideas/Reviews | 1 | 28th August 2007 08:14 AM |
| Binary Count down timer | hugehead | General Electronics Chat | 3 | 8th March 2005 12:49 AM |
| Count-down timer | sword | Electronic Projects Design/Ideas/Reviews | 11 | 18th June 2004 02:03 PM |
| how do i count pulses using timer 0? | vortech1 | Electronic Projects Design/Ideas/Reviews | 3 | 20th April 2004 08:28 AM |
