Old 19th June 2008, 06:18 PM   (permalink)
Default Accessing C:/ Drive
Hi there, whenever I want to access my C drive I a little pop window jumps up and asks me whether I want to open the 'file' with Acrobat, Word, Internet Explorer or Notepad and similar nonsense. What could the problem be?
Everybody can but not everybody will.
aibelectronics is offline
Old 19th June 2008, 06:57 PM   (permalink)
What program(?) are you trying to access c: from?
When you are trying to access c: are you clicking on c:, or someting in it's root directory?
gerty
gerty is offline
Old 19th June 2008, 07:02 PM   (permalink)
It sounds like the type of file that you are accessing is not recognized by your OS. Does it have a funky extension.
Make sure your C drive is ok.
See if you can access your C drive through your command window.
Start---> Run type command
type C:\
Dir
Mikebits is offline
Old 19th June 2008, 07:16 PM   (permalink)
If you mean you go to MY_COMPUTER and then click on the C drive then this happens. If so I would guess it is a messed up file association. If you are using XP go back to a restore point prior to the problem. Maybe some software install went wrong or some one messed up the registry.
3v0 is offline
Old 19th June 2008, 08:36 PM   (permalink)
Default Reply
That's exactly wat I mean 3v0. By 'restore point prior to the problem' do you mean restarting in 'last known good configuration'?
Old 19th June 2008, 08:58 PM   (permalink)
Just check you don't have a file named autorun.inf in the c:\ directory.
picbits is offline
Old 20th June 2008, 11:51 AM   (permalink)
This is a virus but not a serious one.I think its an virus with the *.vbs extension.
That means your virus guard don't know there are plenty viruses inside your PC.
Me & many people got this incident when I use previous versions of virus guards.After installed registered version of kaspersky the problem solved.
Not only the C: drive in future you may locked your other drives as well.
Alternate you can use explorer to view your drives.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 20th June 2008, 03:18 PM   (permalink)
So how do I solve the virus problem? I have threatfire and McAfee installed (Threatfire is the more active of the two :-)
Old 20th June 2008, 03:50 PM   (permalink)
Have you checked to see if you have an autorun.inf on your c:\ ?
picbits is offline
Old 20th June 2008, 03:52 PM   (permalink)
Try this, I've the same problem too and I got this from my friend.
Put these two files into the C drive, execute clean, followed by clean2.
I'm not sure whether they work for you or not, but they remove some trojan in my drives.
Superman returns..
bananasiong is offline
Old 21st June 2008, 03:52 AM   (permalink)
Or when the thing asks you what program to use, select C:/ windows / explorer.exe and that's all
La Rotta
Menticol is offline
Old 21st June 2008, 05:51 AM   (permalink)
I'm sure bananasiong means well, but I would recommend that you *not* download that .zip file, and *not* run the two executables contained within it. You have absolutely no way of knowing where they came from, who wrote them, or what the authors' motives were.
In this case, googling for 'clean.exe clean2.exe' turned up only about a hundred pages, mostly in Spanish and Portuguese, all of which report that clean.exe and clean2.exe are part of a virus or worm of some kind (although in this case, the proper term would be "trojan horse").
In short, never, ever try to solve a problem with some unknown software you find on a forum. Use trusted tools such as HiJackThis, Spyware Search and Destroy, etc, and only download them from trusted sources.
Torben
Curiosity was framed. Ignorance killed the cat.
Torben is offline
Old 21st June 2008, 06:04 AM   (permalink)
Your a wise man Torben.
Mikebits is offline
Old 21st June 2008, 10:43 AM   (permalink)
Torben
Yes, that's true Never trust any unknown person. Even myself, I have no idea who wrote them. I just got it from my friend and they really kill the trojan in my drives (even McAfee is not able to scan them).
Again, it's normal not to believe anyone unknown
Superman returns..
Old 23rd June 2008, 01:08 PM   (permalink)
Well, so which way to go...?
3.5” Hard Drive Physical Size, True 3.5” drive? stevef22 Datasheet/Parts Requests 4 14th September 2007 03:49 AM
Accessing EEPROM Clayton Micro Controllers 15 23rd March 2007 04:00 AM
lots of problems accessing site justDIY Chit-Chat 9 3rd April 2006 01:05 PM
Converting Normal pc cd rom drive to dvd drive litto43ph Electronic Projects Design/Ideas/Reviews 8 29th January 2006 08:09 PM
Indirectly accessing the access bank (18F) pittuck Micro Controllers 1 28th November 2004 08:03 AM
