| I have 2 solenoids that are read by a computer. Each solenoid has about 25 ohms and has 12 vdc applied all the time...solenoids are controlled by a ground supplied from a computer. I currently use two 25ohm, 5 watt resistors to "fool" the computer into seeing the solenoids and want to try and use just 1. How would I figure that out. Basically two grounded computer pins connected to a single resistor, connected to 12vdc. Any help appreciated. THANKS! | |
| So, if I understand your correctly, you want some sort of relay simulator, that is something that has the same I draw as your relays. Using ohms law I=E/R 12v/25 But now you want to simulate two relay (In parallel I presume) so two 25 ohm resistors in parallel equals halve the value of two equal resistors, in this case 25 | |
| Math | hjl4 | General Electronics Chat | 8 | 30th August 2007 12:46 AM |
| Math help? | Mike, K8LH | Micro Controllers | 10 | 9th April 2007 11:07 PM |
| Datasheet 330K 1/4W Resistor and 100R 1/4W resistor | kid | Datasheet/Parts Requests | 9 | 17th February 2006 03:55 PM |
| Math Help | shermaine | General Electronics Chat | 9 | 21st April 2004 02:39 PM |
| Flashing LEDs - resistor or not resistor? | grrr_arrghh | General Electronics Chat | 11 | 19th March 2003 08:23 PM |
