| The Schmitt trigger inputs require VDD*0.8 (4V when VDD = 5V). I've tossed a transistor on the input, although the relay ON should turn off the transistor. | |
| Hi Bill, provided the relay is powered by +12V you've plenty to play with. Use 8K2 for R3 and 4K7 for R1 in the voltage divider. This will give you 0.532V for 'L' and 4.292V for 'H' with the same (as mentioned before) coil resistance of 240Ohm. Using 5K1 for R1 won't change much, but the 'L' condition will also travel upwards. CMOS Schmitt-Triggers are satisfied with lower input voltages. They just require VDD/2 (in that particular case slightly above 2.5V) Hans | |
| Hall effect sensor | carmusic | General Electronics Chat | 1 | 1st April 2008 03:11 PM |
| Hall effect sensor | jjj | Electronic Projects Design/Ideas/Reviews | 2 | 10th January 2008 10:00 AM |
| What type of Hall Effect sensor is cheap and common? for rotation sensor with magnet. | William At MyBlueRoom | Electronic Projects Design/Ideas/Reviews | 2 | 30th November 2006 07:59 AM |
| Hall Effect Sensor | bryan1 | General Electronics Chat | 1 | 16th September 2005 09:21 AM |
| hall effect sensor | koyeh182 | Electronic Projects Design/Ideas/Reviews | 5 | 26th December 2003 03:12 AM |
