| the lower the cost the best but i prefer to spend approx around 50-70usd.Robert,do u have a pic to show about ur previous project?maybe we can share and i might have a clear picture about it...sound interesting... | |
| guys i have a few choices of item to show here but how do i insert the picture inside this forum? | |
| that's a very limited budget considering that you need a pump pipes and controls for that buget you can't use any metal pipes even the grid system with storage tank is not posible you would be better of to use than a different set up the simplest thing you can make is simple pipe work (pvc) drill small holes in it 1 a 2 mm put it on the roof and conect that on the city water system with a solenoid valve the solenoid valve is operated by a temp sensor conected on the roof you will have the build up of minerals and somtimes algea on the roof over time What material is the roof annyway?? Robert-Jan | |
| if you reply the advance way than you can browse in your computer and attach pictures if they're not to big Robert-Jan | |
| which one work best?which type? | |
| they al work good but are absolut useless for roof sprinkeling its better to use a sort of drip line (pipe with wholes drilled in) and put that on your roof Robert-Jan | |
| im not sure the material they use for the roof but i will find it after.I find this project as an approch to go more,that's why i started in low budget as a start.Anyway your guys really helpfull.Thanks,but one thing can anyone help me to design such circuit that able to control valve with the help of termistor/heat sensor? | |
| just use a simple comparator with on one input a voltage divider including a thermistor for switching a triac (as the soilenoid valves i know of are all AC (relais will work also)) Sucses Robert-Jan | |
| An added advantage of rain water is that its soft with few minerals so it shouldn't leave spots on the roof.
__________________ Carl | |
| I posted a link to this earlier but it seems you did not read it. It explains how to buld a roof cooling system on the cheap. North Carolina System Quote:
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
| the sprinkler system showed in the link is not realy perfect they create a mist to cool the air above the roof down before it actualy hits the roof the water is already warmed up a bit and less in quantity (evaporation) a drip line brings the water direct in contact what you want to cool down so it's more efficient its also cheaper to build as for the water quality rainwater is indeed good if you see it in the terms of containing minerals and if you in south east asia it's also safe to drink but in europe you will be shoked how much polution is in the rain water and because of that you can have also different problems with build ups on the surface where you releas it of course this doesn't hapen in a half year closed systems that cool down by convection are way better but the initial instalation cost will be higher still than if you do the work your self they're still a money safer over the years Robert-Jan | |
| thanks everyone for the idea,i will start doing it using direct drip as per rjhv advise.This might help and good too in term of cost.3vo,thanks also and actually i have read it and a few point might be good to implement it.Thanks u guys,u all very helpfull.now i have something to work on...... | |
if any questions do arise don't hesitate to ask keep in mind that you first start with small holes in the pipe and see what the effect is regarding the pressure and water quantity use Upvc pipe if it is subject to UV light from the sun, any metal pipe is also good but already more expensive and harder to plumb your self for the most people no PVC or HDPE as these pipes not realy last in the sun Robert-Jan | ||
| If you or others live in a climate zone that requires a roof to be sprinkled on sunny, hot days, why not have the roofing material be ceramic tiles... just like it is along the Mediterranian, Mexico and so on?
__________________ Don't make me reach through this monitor to slap you a good one! | |
| LED house sign | sammy004 | General Electronics Chat | 18 | 19th April 2008 06:31 AM |
| Bark activated sprinkler system | Ray Bearden | Electronic Projects Design/Ideas/Reviews | 10 | 29th November 2007 02:57 AM |
| Lawn Sprinkler Timer | VegasMonkey | Electronic Projects Design/Ideas/Reviews | 3 | 1st October 2007 07:10 AM |
| Voice Over Powerline (in-house) | le_chiffre | Electronic Projects Design/Ideas/Reviews | 25 | 17th January 2006 03:41 AM |
| We are searching for the Desigh House !!! | Alex Konstantinovski | Electronic Projects Design/Ideas/Reviews | 8 | 23rd October 2004 03:37 PM |
