Old 12th June 2008, 10:00 PM   (permalink)
Default Solenoid switch circuit verification
Hi can someone verify my little circuit please.
When I switch on I need 0.1A to go one way through a solenoid and when I switch off I need the 0.1A to go the other way.
Much appreciated.
Craig
richacm is offline
Old 12th June 2008, 10:06 PM   (permalink)
Can you use a center off double pole switch? Really easy to reverse current with one.
Your circuit has floating bases, you may want to add a couple more resistors to keep the tied to power & gnd.
Bill
Smart Kits build Smart People
Old 12th June 2008, 10:10 PM   (permalink)
Yeah I can use what ever I like....I just thought transistors would work ok.
Instead of having a manual switch I am going to send 5V directly to the Base of the transistors from a PIC chip. I.e. to turn ON I send 5V to the Base of the ON transistors and OFF sends 5V to the Base of the OFF transistors.
Thanks.
Craig
richacm is offline
Old 12th June 2008, 10:11 PM   (permalink)
Cool, will have a look
richacm is offline
Old 12th June 2008, 10:14 PM   (permalink)
You need two PNP and two NPN transistors.
mneary is offline
Old 12th June 2008, 10:22 PM   (permalink)
Thanks for that...missed the PNP, NPN relations.
Attached is new circuit. I still have floating bases though as pointed out by blueroom....how do I stop that?
Cheers,
Craig
richacm is offline
Old 12th June 2008, 10:26 PM   (permalink)
Sorry I didn't notice before... you also need to swap the PNP emitters with one another.
Your bases won't be floating when you hook them to the PIC.
mneary is offline
Old 12th June 2008, 10:33 PM   (permalink)
Sorry I don't follow that one. The PNP Emitters go to either solenoid terminal to make the current go from 0.1A one way or 0.1A the other way....that's correct isn't it? Oh that little symbol in front of the 0.1A is a ~ for approximate. It looks like a "-" negative when its small.
Ah ok.
richacm is offline
Old 12th June 2008, 10:42 PM   (permalink)
Can you put numbers on the transistors? Would be easier to explain.
mneary is offline
Old 12th June 2008, 10:47 PM   (permalink)
Numbers attached.
richacm is offline
Old 13th June 2008, 02:45 AM   (permalink)
I think I know what you mean....I needed NPN transistors didn't I?
As in the diagram.
richacm is offline
Old 13th June 2008, 06:17 PM   (permalink)
Transistors 2 and 4 should be PNP. Emitters 1 and 2 should be connected together. Emitters 3 and 4 together too.
Sorry I took so long to reply, my internet at home is down.
mneary is offline
Old 13th June 2008, 08:24 PM   (permalink)
But if 1 and 2 emitters were connected together then the current would go straight to ground wouldn't it? I wouldn't get any current going through the solenoid.
Sorry I am not following what you mean.
richacm is offline
Old 13th June 2008, 08:37 PM   (permalink)
Here's what I mean: The two inputs are MCU ports. Won't work with a switch without additional resistors. Probably should replace the 1Ks with 220 or 270 ohms.
mneary is offline
Old 13th June 2008, 08:52 PM   (permalink)
Thanks, but when the Off/On switch is on wouldn't there be a straight path down to ground missing the solenoid?
EDIT: I think I am not clear on what a PNP transistor does. Is it the opposite of an NPN? In that it is on when the Base is Low and Off when the base is High?
richacm is offline
PWM driver circuit for solenoid waginia Datasheet/Parts Requests 14 29th March 2007 03:42 PM
I need a switch circuit please ahonda55 Electronic Projects Design/Ideas/Reviews 7 2nd April 2005 01:48 AM
where to buy this solenoid? daviddoria General Electronics Chat 6 2nd June 2004 09:55 AM
what is the switch for in this circuit?? bonanz General Electronics Chat 1 11th November 2003 11:21 PM
What is a solenoid???.... eyevancsu General Electronics Chat 6 10th May 2003 02:09 PM
