Old 13th June 2008, 10:22 PM   (permalink)
When the top input is high, T1 acts as an emitter follower and its emitter is at approximately 5V-Vbe. T2 is not conducting. When it is low, T2 acts as an emitter follower and its emitter is at approximately GND+Vbe, and T1 is not conducting.
Similarly for the other input, with T3 and T4 respectively.
Note that as emitter followers T2 and T4 don't turn on unless their bases are actively pulled towards GND.
Consider the following 4 cases:
A) HIGH/LOW - T1 emitter pulls to 5-Vbe. T4 emitter pulls to GND+Vbe. Coil receives +5V-(2*Vbe).
B) LOW/HIGH - T2 emitter pulls to GND+Vbe. T3 emitter pulls to 5V-Vbe. Coil receives -(+5V-(2*Vbe)).
C) LOW/LOW - T2 emitter pulls to GND+Vbe, T4 pulls to GND+Vbe. Both ends of coil at the same potential.
D) HIGH/HIGH - T1 emitter pulls to 5V-Vbe, T3 emitter pulls to 5V-Vbe. Both ends of coil at the same potential.
mneary is online now
Old 14th June 2008, 02:59 AM   (permalink)
thanks for the explanation...it made sense.
I tried it out on my solenoid and it worked fine when I changed the bases from 5V to 0V on either transistor. I then connected it up to my PIC chip and drove the base via that. However this didn't work.
I am setting PORTE.0 and PORTE.1 as the two outputs. I set PORTE.0 to $FF and then PORTE.1 to $0 and I would expect the bases to be 5V on RE0 and 0V on RE1 however RE1 carries a voltage of 1.4V and instead of the negative terminal being 0V it is 2.2V and the positive is 4.9V going in to the solenoid. Is there any reason why this would be?
Thanks,
Craig
richacm is offline
Old 14th June 2008, 09:38 AM   (permalink)
My actual voltage differential across the solenoid is only 2.5V either way....I'm a bit confused as to why? Any ideas how to correct this?
richacm is offline
Old 14th June 2008, 09:42 AM   (permalink)
G'day Rich,
Which circuit version are you using, any chance of a posting, of the latest.?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 14th June 2008, 03:14 PM   (permalink)
Between the 20ohm resistor (why is it there) and the voltage drop of the two transistors (0.7V each)
Bill
Smart Kits build Smart People
Old 14th June 2008, 11:20 PM   (permalink)
With the Vbe drop of the transistors, the 20 ohm resistor is no longer needed.
My bad for forgetting to mention that. I blame it on 48 hours without DSL.
Old 15th June 2008, 09:58 PM   (permalink)
Ya it worked. Thank you so much. Just need to read up my Uni Electronics book now to figure out why
Cheers again!
Craig
richacm is offline
PWM driver circuit for solenoid waginia Datasheet/Parts Requests 14 29th March 2007 04:43 PM
I need a switch circuit please ahonda55 Electronic Projects Design/Ideas/Reviews 7 2nd April 2005 02:49 AM
where to buy this solenoid? daviddoria General Electronics Chat 6 2nd June 2004 10:55 AM
what is the switch for in this circuit?? bonanz General Electronics Chat 1 12th November 2003 12:21 AM
What is a solenoid???.... eyevancsu General Electronics Chat 6 10th May 2003 03:09 PM
