I have ripped apart a solenoid I found which controls water flow. I can't find out anything about it on the internet and there is no part number on it. However its part of a Gardena T14e water timer which switches on and off the water at pre-set times. I tried to get readings from the unit when it sent messages to the solenoid...however my multi meter just picked up a very low V spike - I'm guessing that the signal may have been digital???? Anyway I blew up the unit during my testing Thanks heaps, Craig |
what is the suply voltage of the whole unit??
can you find some regulator inside that indicate a lower voltage or not ? can you messure the coil of the solenoid (how many Robert-Jan |
The solenoid is completly sealed, I can't get in there at all....not much help I know! |
as it is already broken than why not try to open it (brutal force)
and try to get the leads of the solenoid most likely you can retrieve the leads and operate it this way try with 5 V for activation and step it slowly up if that doesn't works Robert-Jan |
Hey I am making progress! I figured out that to open the switch I need a 0.1A surge to the sensor. So I place a 5V supply with a 100
if you have a 5V with a 100
can you measure the resistance of the coil? to operate it it's just simple let a current through or not (put a switch in series) Robert-Jan |
It may be a latched solenoid, does reversing the battery close it?
Mike. |
It is latched. I reversed it and the current went way up - short circuited 1.25A...must be a diode of sorts inside the solenoid. The solenoid didn't open though.
33.3Ohm resistance in the solenoid when I put the multimeter across it. Last edited by richacm; 12th June 2008 at 09:39 AM. |
Are you saying once energised the valve remains open, even when the power to the solenoid is removed.? Is this an 'air' test or with actual water,?
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
Yes Eric, that's what happens.
There is a little washer sitting on a spring on top of the solenoid. When 0.1A goings in to the solenoid it magnetises it and sucks the washer on to the solenoid thus opening up the valve. You can then release the 0.1A and it remains magnetised to the solenoid - i.e. stays open without any power. You then need to pass X to the solenoid and it releases the magnet. I have tried from 1A down to 0A to no avail at this point. Craig |
I have looked at the spec for the Gardenia water drip feed system, I suspect the valve requires water pressure to reclose the valve correctly. The pulses just pop the valve open for an instant, then it recloses. The overall system is fitted with a water pressure regulator to ensure correct operation.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 12th June 2008 at 07:35 PM. |
I tried it (when the control unit worked) and when I clicked on it sucked the magnetic on to the solenoid and when I clicked off it released the washer. I.e. it popped up and down on the solenoid. So I'm pretty sure I should be able to do the same thing without the need for water.
I'll try a few more things today with it and see how I go. I really like this one though cause it doesn't need a constant holding amp. Most solenoid values I see have an inrush amp of 0.4 and then they need a holding amp of 0.2 to keep it open. This one doesn't which is really cool. It also works off of 5V as well. Cheers, Craig |
I got it....sorry I stuff up the reversed setting. It's 0.1A current surge to open and -0.1A current surge to close
Cheers everyone |
| solenoid problem | ritayshida | General Electronics Chat | 16 | 14th December 2005 11:58 PM |
| What does AC sq wave do to a DC solenoid? | Oznog | General Electronics Chat | 2 | 6th July 2004 12:23 PM |
| where to buy this solenoid? | daviddoria | General Electronics Chat | 6 | 2nd June 2004 09:55 AM |
| Solenoid Valves | brentonw2004 | General Electronics Chat | 7 | 10th December 2003 12:12 PM |
| What is a solenoid???.... | eyevancsu | General Electronics Chat | 6 | 10th May 2003 02:09 PM |
