+ Reply to Thread
Results 1 to 10 of 10
Thread: Wiring for home security alarm
  1. #1
    hychong69 Newbie
    Join Date
    Jun 2008
    Location
    Melbourne, Australia
    Posts
    4
    Question Wiring for home security alarm
    Our house is in construction and I am looking at putting the wiring in for the security alarm myself and have it install after the house is completed. What type of wiring cable should I use for the panel, keypad, reed, PIR, internal and external alarm. Can I create a loop to connect a few PIR on the same wiring? Any advise is welcome. Thanks in advance.
  2. #2
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,821
    Wire is cheap when the walls are open. I would home-run cat5 (or if you need it cheap, quad or twisted pair) to the alarm box from each location that you plan to have a sensor.
  3. #3
    hychong69 Newbie
    Join Date
    Jun 2008
    Location
    Posts
    4
    Question
    I think I will not consider CAT 5 cable as it is a bit dear. Is quad sufficient? I just had a look on the net and PIR got Relay, EOL and Tamper connections. Should I be worry about those connections?
  4. #4
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,821
    Quad is sufficient if your sensors need 4 or fewer wires.
  5. #5
    hychong69 Newbie
    Join Date
    Jun 2008
    Location
    Posts
    4
    mneary, I think I'll just go for the quad for the sensors as you advised. I believe I need a 6 core for the keypad. Quad should be sufficient for both internal and external siren. Thank you for your advice.
  6. #6
    yngndrw Newbie
    Join Date
    Jul 2007
    Location
    England, North West
    Posts
    286
    PIR sensors usually require 6 cores.
    * 2 for power.
    * 2 for data / signal.
    * 2 for anti-tamper loop.
    I think the bell boxes require more than 6 cores, but can't remember.
    Edit: Found something for you: DIY Alarm Install - Installing an Intruder Alarm System - Security Installer Happy birthday.
  7. #7
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,821
    Make sure your wire to the external siren is heavy enough.
  8. #8
    hychong69 Newbie
    Join Date
    Jun 2008
    Location
    Posts
    4
    Smile
    mneary, can you please explain "wire to external siren is heavy enough".
    yngndrw, thank you for the link.
  9. #9
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,821
    Your quad is probably 26 or 24 AWG, which is safe at 1 or 2A at most. A siren may require more current than this. Check the ratings.
  10. #10
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,457
    Many ready made alarm circuits have termination resistors for each loop. To prevent false triggering shielded cable should be used for the entire field wiring. This is also prescribed by home insurance companies in Germany in order to decrease the insurance rates to be paid.
    Noncompliance will lead to normal rates (the same to be paid without alarm system).
    Check for your home insurance regulations concerning wiring. If you don't intend to buy an insurane you might use any conductive material for wiring.
    Boncuk
+ Reply to Thread
  1. home security system
    By mayankguru in forum Electronic Projects Design/Ideas/Reviews
    Latest: 15th October 2007, 05:37 AM
  2. Best home made security circuit
    By flemmard in forum General Electronics Chat
    Latest: 11th September 2007, 07:04 PM
  3. Home Wiring
    By Badar in forum General Electronics Chat
    Latest: 31st March 2007, 11:06 PM
  4. need help on home security project
    By crazytwism in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st March 2005, 08:26 AM
  5. Building a complete home security perimeter system...
    By RaetherEnt in forum Electronic Projects Design/Ideas/Reviews
    Latest: 6th November 2003, 06:05 PM
Tags for this Thread
