Old 8th June 2008, 02:00 AM   #1
Question Strobe sound-to-light pulse trigger circuit.
Im new to this forum and this is my first post. I run a mobile disco business with a friend and have a Prolight 1500W strobe.
Im planning to build this controler circuit for it: Strobo controller. I want to modify it and add a sound-to-light function using the speaker output or preout of my amplifier as the input
A solution I was thinking of was to design a filter circuit using an op-amp with a zener diode or schmitt inverter (e.g. CMOS 40106) in some way so as to only let the peak audio signals through.
The output would be connected to pin 2 of the 555 in the Strobo controller circuit above.
I have tried using velleman kit MK114, but it is designed for halegen bulbs and too unstable for a strobe. Schematic: http://www.velleman.be/images/tmp/MK114.jpg
Note: I connected pin 6 of the 4N35 to ground via a 47K resistor. If disconnected, pin 6 is floating and the output is always on.
Please do not attach images of PCB layouts. I do not have the neccessary equipment to make my own PCBs.
I use StripboardMagic to draw the schematic and convert it to a draft stripboard layout. I then use Lochmaster 3.0 to design the final stripboard layout.
Thanks in advance for any advice and sorry about the long post
simontay1984 is offline
Old 8th June 2008, 06:47 PM   #2
No one going help??
Old 8th June 2008, 07:06 PM   #3
Originally Posted by simontay1984 View Post
No one going help??
We will try.
Looking at the 'strobe' cct, its an astable.
Which aspect of the 'light' do you want to control, intensity or on time.?
and over what sort of frequency range.?
ericgibbs is offline
Old 9th June 2008, 01:52 AM   #4
Default Trigger..........
Here is a link that might give you some ideas:
DIY - Universal Sound and Optical Slave Flash Trigger | DIYPhotography.net
Rolf is offline
Old 13th June 2008, 04:40 PM   #5
Talking Strobe trigger circuit: schematic found!
Hi, sorry for the delayed reply, ive not had internet access for a few days.
I found this page which has the ideal circuit I need:
Elliott Sound Products - Project 62b - LX-800 Lighting Controller
Due to its complexity, im going to draw out the schematic in some suitable software I like then use a PCB layout program then send the file(s) to a PCB manufacturing company.
controler, pwm, sound to light, strobe, trigger
Trigger 555 with positive pulse ghall426 Electronic Projects Design/Ideas/Reviews 6 8th June 2008 06:15 PM
Simple pulse trigger help jmb4370 Electronic Projects Design/Ideas/Reviews 8 16th December 2007 01:39 AM
strobe light jrz126 General Electronics Chat 16 12th July 2007 08:11 PM
Request 48V DC strobe light circuit tnrmoorthy Electronic Projects Design/Ideas/Reviews 4 21st July 2006 06:23 PM
strobe sound Josh General Electronics Chat 6 24th September 2003 07:57 AM
