Notices
Old 7th June 2008, 02:48 PM   (permalink (permalink))
Default Operate Relay Over Certain Voltage
I have a refrigerator on my boat, and it takes a fair bit of current from the 12V supply. I would like to make a circuit such that it was only switched on when the battery was charging, say over 13.2V.
I think it would be best to use a LM311 comparator (datasheet here), but I'm not sure about the ancillary components.
One issue to consider is that when the relay fires, the load of the fridge will cause a dip in the supply rail. If there is not some form of damping, this will cause the circuit to switch off, then the voltage will rise, and the circuit will switch on ...
Any suggestions?
Big_Nige is offline
Old 7th June 2008, 08:46 PM   (permalink (permalink))
Run your sensing circuit from the 12 volts supply rail via a diode (1N4001) .
The sensing circuit will run at the accu voltage minus 0.6 volts.
If you sensing circuit has a big capacitor at it's input supply rail, the voltage dip is blocked by the diode and the sensing circuit takes the supply from the capacitior during the dip and is unaffected.
Try 4700 uF 35 Volts to begin with and see how it goes.
Regards, Raymond
RODALCO is offline
Old 7th June 2008, 09:16 PM   (permalink (permalink))
This will do the job.
What turn-off voltage do you require?
I've assumed about 12V.
Screen name: Aloone_Jonez
Hero999 is offline
Old 8th June 2008, 09:59 AM   (permalink (permalink))
Many thanks for that.
I hadn't considered that the turn-on and turn-off voltages could be different, and I'm not sure I want them to be. However, I guess it gets round the problem of oscillation.
I will do a test and see what the voltage drops to when the fridge turns on, and for how long...
Big_Nige is offline
Help With Building Low Voltage Relay For School DoktorD Electronic Projects Design/Ideas/Reviews 2 22nd November 2007 09:16 PM
Trying to build a DC voltage monitor/relay abailey1959 Electronic Projects Design/Ideas/Reviews 1 3rd March 2006 02:31 AM
Operate a relay from a PC port RS232 or Parallel port Eddie ESV Electronic Projects Design/Ideas/Reviews 2 12th June 2004 07:43 AM
Relay spike voltage cdr General Electronics Chat 7 9th June 2004 02:18 AM
Relay Firing Voltage Alpisces General Electronics Chat 4 10th March 2004 06:26 PM
