Old 7th June 2008, 12:15 PM   (permalink)
Default Ultrasonic Range Finder (95% done,need your 5%.;ref. inside)
Hi guys, im currently doing a displayed ultrasonic range finder,i got my diagram from here,
http://www.best-microcontroller-proj.../pic-sonar.pdf
A PIC sonar (ultrasonic) range finding project. (the main site)
I've finished breadboarding everything (triple checked it)
alas, nothig turned out on my display. (pic. attached)
I program my PIC with a generic PIC kit (pic. attached) with a given code from the site. But i think that i may have done something wrong in the programming part ( i just directly inputted the hex. file ) and im very bad at programming..If someone could tell me how should i 'properly' input the .hex file, i would be really happy.
i really apreciate your guys help.
di@ne is offline   Reply With Quote
Old 7th June 2008, 12:28 PM   (permalink)
oh yeah, il send u guys a postcard from malaysia if i get my stuff working
Old 7th June 2008, 12:58 PM   (permalink)
Did you set the configuration bits correctly when you programmed it ?
If you haven't set the oscillator type/watchdog/etc etc in the config bits then it won't work properly (if at all).
picbits is online now   Reply With Quote
Old 7th June 2008, 01:01 PM   (permalink)
Also, how are you powering it ? I see you have at least 4 cells. If you are driving the PIC with those without a voltage regulator and they are fresh cells then you are going to have more than 6 volts going into the PIC. This is out of spec and could damage the PIC.
If you are using a voltage regulator in the circuit then you might find that unless its a very low dropout regulator, you won't be getting 5 volts out of it unless you use at least 7-8 volts at its input.
Old 7th June 2008, 01:03 PM   (permalink)
And finally - are you sure your PIC is in the right place in that programming socket and the right orientation ?
Old 7th June 2008, 06:41 PM   (permalink)
1. Dear Picbits, i am not sure how to set the configuration bits, is it possible to tell me more or send me a link where i can study more about it?
For the oscillator, i believe it has been set in 4Mhz the stock source code given where i just "simply" programmed it.
2.
A direct reading from my cell is going 4.78+- volts but from your suggestion i am going to fix a 5 V voltage regulator soon to prevent any complication.
I am not that experience,but i guess that my PIC is still
functioning properly since i still can erase and reprogrammed any given .hex
3. for the programming sockets, i followed the instruction from the data sheets given for an 18 pin (attached)..Is it any difference to programmed it with my socket model then a direct ICSP type programming from the diagram? and for the wiring orientation from my PIC to the display and others,i checked everything and it seems to be correct, i checked every pin from 1 to 18.
4. and for my ultrasonic (attached) im not sure how i connect it but i guess it is correct, is there any polarity where + - goes to?
thanks.
on something else that is not related, for all of this problem i would ussually have an assistance from my course coordinator, but as you can see ( www.shienandy.com - Welcome ) ; i haven't have the chance to have a proper communication with him for a month since his gettting married and all other things his going thru...and basically i am doing most of the things with the help of people around me and the net.
File Type: pdf UIC00A & UIC-S V1.6 Downloaded Online.pdf (1.48 MB, 1 views)
Ultrasonic Range Finder AtomSoft Electronic Projects Design/Ideas/Reviews 5 12th February 2008 04:36 AM
Ultrasonic Range Finder admin2far Electronic Projects Design/Ideas/Reviews 1 13th July 2007 03:14 AM
Ultrasonic Range Finder admin2far Robotics Chat 0 9th July 2007 09:11 PM
Ultrasonic range finder epilot Electronic Projects Design/Ideas/Reviews 8 12th August 2006 10:46 PM
Ultrasonic Range Finder HELP! demokesola Electronic Projects Design/Ideas/Reviews 6 19th August 2005 09:05 PM
