Old 23rd October 2003, 12:51 AM   (permalink)
Default Need help in zero crossing detector
can someone tell me wat is a zero crossing detector? wat does a simple zero crossing detector consists of??? do anyone have any schematic that can give me??? Sorry for asking so many qns but really need help here. thks.
Regards.
losT is offline
Old 23rd October 2003, 09:12 AM   (permalink)
With zero-cross switch in AC application You can make noiseless on-off.This mean the load switched off or on when the voltage about zero on it. Most of case optotriacs contains this circuit (MOC 3041).
Here is a primitive sematic for better understandig.
Sebi is offline
Old 23rd October 2003, 11:34 AM   (permalink)
Default zero-crossing detector
What are you using the detector for? Sebi's right, but if it's just going to be used for timing applications, a true zero-crossing detector isn't necessary. Any circuit that switches at the same point in each AC cycle will work. A voltage divider on a transformers' secondary, followed by schmitt trigger or comparator can generate a square-wave for timing purposes.
laroche73 is offline
Old 27th October 2003, 05:46 AM   (permalink)
I have a project which need me to design a zero-crossing detector. Therefore I need to know wat a zero-crossing detector is. is the picture a zero-crossing detector???? My input is a noisy ac voltage and output a digital 5V pulse.
losT is offline
Old 13th November 2003, 01:04 PM   (permalink)
Default Re: Need help in zero crossing detector
Hey I am telling you what I know about simplest Zero Crossing Detector
Zero Crossing detector is a comparator whose reference or threshold voltage (which is applied at one of the two terminals of the op-amp)
is made zero.
It is used to get a perfect square wave from a sine wave.
If a capacitor and a diode with two resistors (another network) are added
at the output of the simple zero crossing detector then pulses are obtained at the output of the network. (The input of the network is the output of ZCD)
cruel_intentions1984 is offline
Old 3rd May 2008, 07:54 AM   (permalink)
Default Zcd
hi
how this circuit work?
please give some details of the circuit u attached..
shahtejasm is offline
Old 3rd May 2008, 08:22 AM   (permalink)
Originally Posted by shahtejasm
hi
I would suggest you start a new thread, this one is 5 years old.!
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
