Ok, so my brother insists i make him a rapid firs ps3 controler. i realy dont want to pay for a kit when i know i can make one.
here is the layout of the ps3 controler. I have a 5V input and a ground. then also for the "trigger" there is 2 connectors that just need to have a connection to fire (dont know the term but if you were to touch the two together it would fire) so the idea is to be able to have a new push button that will start the rapid fire. i was thinking it could be dont with transisters, resisters and capacators. but that is as far as i got. can someone come up with an idea? |
look at using an 74HC4066 analog switch and a 555 timer...
rgds |
thanks, howerver im a noob at this stuff and if you can can you tell me how it would go together. also is the 74HC... common? like can i find it at frys? also i searched and found this Playstation 3 Rapid Fire PS3 Controller mod kit COD 4 - eBay (item 360058264582 end time Jun-12-08 15:57:26 PDT) is one of thoughs the 74HC? if not do you know what they are?
well let me try to take a wak at this. So on the 555 timer:
Ground goes to pin 1 and the 5V goes to pin 8. Then you have a emp switch followed by a 200,000 ohm resister connected to the +5V then connected to a 1 uF capasitor. the capasitor negitive term is connected to the ground and then the possative goes to the trigger (pin 2). Im not sure what to put for the reset. but then the output (pin 3) goes to (im guessing here i can not find much info) pin 13 on the 74HC. ground to pin 7 and +5V on pin 14. Then pin 1 and 2 are the switch on the controler. now back to the capasiter and resister, i looked on a site and i think that combo should equate to a .2 sec fire rate. is this correct? i hope i got it all right. like i said i think i need something on the reset but i dont know what it would be. |
Can you post a drawing.?
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
i think you still don't have the whole consept in your mind try first to put idea in a block schematic (2 blocks) timer and switch than have a look at the 555 datascheet (try various manufactors) and study the way the several configurations of the ic and the pick the one you need than look at the data sheet for the 4066 and combine sucses Robert-Jan |
ok, yeah im compleatly new at this. my traning is takeing stuff apart an seeing what works. So last question i think of the nite. Is the 4066 a common component? like can i find it at frys?
The 4066 ( and the very similar 4016 ) are common components yes. However, I have no idea whom or what " Fry's " is.
Edit: FRYS.com*|*I.C's Passives / Expaned IC's FRYS.com | I.C's Passives / Expaned IC's Yes, you can get it at Fry's. Last edited by House0Fwax; 6th June 2008 at 04:57 PM. Reason: I found out what 'Fry's' was. |
ok, so i got both the 555 and the 4066 and the 4016 (just in case i have a feeling i may blow one out) and im stuck. I got a 555 with a typical application layout but i tried it and looked at it with my ossiliscope and did not see anything. can someone help me with this
also with the 4066, is it ment to be extreamly small? i thought it would be the kind i can plug into a bread board. |
a SMD version is not possible to put on a bread board and also can you post the layout of the PS3 controller as you mentioned in your first post?? is it the intention that the rapid fire only works when the button is pushed in at the same time?? Robert-Jan |
well i got the only one they had which i guess is the smd by the looks of it. but do they sell dil versions?
also here is the layout. http://img521.imageshack.us/img521/5...trollermw6.jpg i hope it is good enough. its not my image just fyi. And last, yes i would want it to only rapid fire when the button is pressed but i would put my own switch in. |
did you try already if it works if you put your push button between the 2 contacts that you nominate already for the rapid fire
maybe it works already without any IC ? Robert-Jan |
no, if you short the two contacts it just fires once. shorting them is the equilvlence to pressing the button so i want the ic to switch quickly enough it fires fast
ok i get the full picture now
is it the intention that you build the aditional componets in the controlor consol self ? Robert-Jan |
| project ideas for final year project! | AceOfHearts | Electronic Projects Design/Ideas/Reviews | 3 | 24th April 2007 05:42 PM |
| need suggestions on uni project. (mechatronics project) | konzen | General Electronics Chat | 16 | 13th March 2006 11:56 AM |
| electronics project for btech mini project | sujith123 | Electronic Projects Design/Ideas/Reviews | 4 | 23rd September 2005 11:28 PM |
| i need a project idea\concept for a 10 month project..... | mackoy | General Electronics Chat | 3 | 21st February 2005 11:27 PM |
| biomedical project(electronic project) | naguru | Electronic Projects Design/Ideas/Reviews | 1 | 2nd November 2004 11:07 AM |
