Notices
Old 7th June 2008, 07:01 AM   (permalink (permalink))
yes, there is a lot of room to spair though. so i can easly build it all into it
brianmay27 is offline
Old 7th June 2008, 07:16 AM   (permalink (permalink))
Ok try this site (have problems of making the link)
LM555 Timer Circuits
here you find all sorts of configurations for the 555 you want to use the basic astable oscilator circuit
on the out put of the 555 you conect the controll terminal from the 4066 swich and the switch contact you conect with the points on your controller board
off course you need to conect the power and ground to the IC
sucsess
Robert-Jan
rjvh is offline
Old 7th June 2008, 07:22 AM   (permalink (permalink))
wow, looks great! thanks.
also do you have any guess what you think the responce rate on the controller is? i want to make there be as many fires as i can get but make it so it can still see the trigger fireing
Old 7th June 2008, 08:36 PM   (permalink (permalink))
ok so i need help. I set up the 555 switch like you said but now im faceing a problem. I set it up with 2 10k resisters and a 10 MF capasator which should have a .13 high time and a .06 low time so im looking at it through my ossilascope and i plug a 9V battery into it and it is fast at the beginning (still it is only like a up of 1 and a down of 1 but then it gets slower. about 5 high and 5 low. What is wrong. my battery is reading 8.5V so it should be good if the 555 needs 5
Old 7th June 2008, 08:53 PM   (permalink (permalink))
ok, so it seemed to be a bad 555 timer. i swtched it out and now it seems to work but still seems too fast
Old 7th June 2008, 10:20 PM   (permalink (permalink))
ok got it.
So i hooked the whole thing up and it works SO well. THANK YOU ALL so much!
electronics project for btech mini project sujith123 Electronic Projects Design/Ideas/Reviews 11 9th October 2008 07:25 AM
project ideas for final year project! AceOfHearts Electronic Projects Design/Ideas/Reviews 3 24th April 2007 05:42 PM
need suggestions on uni project. (mechatronics project) konzen General Electronics Chat 16 13th March 2006 11:56 AM
i need a project idea\concept for a 10 month project..... mackoy General Electronics Chat 3 21st February 2005 11:27 PM
biomedical project(electronic project) naguru Electronic Projects Design/Ideas/Reviews 1 2nd November 2004 11:07 AM
