I have six 0-5V duty cycle signals coming out of an ECU that drive 6 direct injectors. However, I need to invert these signals and was considering the 4049 CMOS chip. Is this a good solution?
Also, I need to change the duty cycle signals to 0-12V. Any suggestions for this? Thanks, JP |
What current do you need?, simple open collector transistor drivers with pullups to 12V will both invert and change the signal to 12V - it's far easier to do this if you're inverting at the same time (as you are).
The circuit will be driving six 12ohm solenoids (fuel injectors).
I liked the idea that the single 4049 CMOS chip ($0.30) has 6 drivers which is perfect for this 6 cylinder engine. Otherwise I'd have to run 6 transistors. Can you elaborate on your idea? Thanks for the response! JP |
A CMOS logic chip can't feed a solenoid, it has no where near the capacity.
Check the relay driver circuit on one of my tutorial pages at Nigel's PIC Tutorial Hardware Extras This inverts, and drives the solenoid direct, assuming it's switched in the negative lead. You would need to use transistors with enough gain, and current capacity. |
What do you think about using ULN2803A?
JP |
You could try it and see, but I suspect it will get too hot?.
Sorry, let me clarify I wleft some vital information out.
This signal will not be driving the fuel injector directly, rather it will be going through a controller which is about 62ohms and inductive than the controller will be driving the 12ohm injector. Do you think heat will now be a problem? |
http://www.st.com/stonline/products/...6/uln2803a.pdf
Do I parallel the 12V pull up resistor at pins 13-18? Also, will 1K ohm resistors be good? Thanks for all the help Nigel! |
OK, I am kind of confused on what I hook up to pin 10? Pin 10 is the common for the free wheeling diodes.
The input will be a duty cycled 0-5V signal and I need the output to be a inverted duty cycled 0-12V signal Last edited by quick108; 6th June 2008 at 08:37 PM. |
(permalink) | ||
Think of a switch and a bulb - you can connect the bulb to 12V and the switch down to chassis, this is SINKING current, or you could connect the bulb to chassis and the switch to 12V, this is SOURCING current. |
Luckily it needs to sink current. Are there any other components I need to wire in to make this circuit work properly?
No, the ULN should be all you need.
| EFI Fuel Circuit | akajee | General Electronics Chat | 2 | 17th January 2007 06:45 AM |
| automotive fuel sender unit / fuel gauge | drage | General Electronics Chat | 6 | 20th October 2006 06:37 PM |
| Fuel injector pulse detector | brjones | Electronic Projects Design/Ideas/Reviews | 3 | 31st August 2004 08:07 PM |
| Signal tracer/injector circuit diagram required | ChrisZ | Electronic Projects Design/Ideas/Reviews | 2 | 24th August 2004 11:15 AM |
| Octal Inverter/Hex Inverter? | gtiboy2001 | General Electronics Chat | 3 | 6th November 2002 11:24 PM |
