If youve been around for awhile, chances are you've seen my other thread(s) about it. I came across the board the other day, and now that I have a bit more experience, I figured I'd give it another shot.
The wall wart puts out ~6.9v, so it's pretty unregulated. The top chip is an RT9202 Single Synchronous Buck PWM DC-DC Controller, but I dont know what the bottom chip is - it says this on it: 9936 Δ31B9M Anyways, as you can see in the picture, one one side of the chip, I have power, but on the other side, nothing. This could be why I have no power on the rest of the board. If you have any ideas, need more info, or want to talk to me on MSN (so you can say try this and I can try it and tell you what happens in real-time), let me know. I would greatly appreciate any input! EDIT Ignore the flux residue on CA14, I touched it up with a soldering iron (along with the rest of the points in the area) to make sure there were no cold joints. Last edited by ParkingLotLust; 4th June 2008 at 08:33 PM. |
I don't know.
Did you measure the voltage at the other pint? Perhaps if you trace out that section of the circuit it might give you a clue. As a total guess it's likely to be an op-amp or some sort of voltage reference.
Could the chip be one of these? That would explain why pins 7 and 8 are connected together - if the FET was burnt out, that would cause it to not output, right? I'm not really familiar with FETs as I havent used them before.
http://web.archive.org/web/200601130...O8/CEM9936.pdf Last edited by ParkingLotLust; 5th June 2008 at 01:55 AM. |
No suggestions, ideas, anything? Didnt think it would be that difficult for you guys to figure out
That large inductor [enamalled copper wire] near the bottom of the picture, the soldering looks as dry as old boot... Scrape off the enamel from the wire and resolder to the pcb.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 5th June 2008 at 02:10 PM. |
Didnt help. Next
to the top!
bump bump bump.
Look at Fairchildsemi or Vishay Si9936 dual MOSFET. 4R7 in series with each gate, wired as totem pole, perfect match.
Would anyone be able to order one for me, and mail it up here? Mouser wants $15 just to ship two chips to Canada, and I know it sure as hell doesnt cost that much to drop a couple chips in an envelope.
Mouser # 781-SI9936BDY-T1-E3 (The Fairchild one is obsolete and Digi-key doesnt stock them). Last edited by ParkingLotLust; 12th June 2008 at 03:26 AM. |
You can probably use Si4834. I found 20 pcs on ebay for $4.50 plus $1.35 shipping. Send him an email to see if he ships to Canada. If he won't, send me a PM.
Don't know how I missed it. He ships to Canada for US$1.75. Lots better than $15.
Awesome man, Ill pick that up and drop one in
Could the PWM chip be bad? Any way to tell without buying another one? While the experimenting is fun, I have no use for the other 19 mosfet chips, and if I have to order bulk PWM chips, I will have no use for them either. Last edited by ParkingLotLust; 23rd June 2008 at 11:34 PM. |
| WRT54G Power Supply Chip | ParkingLotLust | Datasheet/Parts Requests | 32 | 5th January 2007 09:26 PM |
| Anyone has schematic of WRT54G? | bbiandov | General Electronics Chat | 3 | 5th January 2007 03:16 AM |
| Lumens & Lamina power LEDs | Oznog | General Electronics Chat | 0 | 25th February 2005 05:58 AM |
| PIC power supply for LEDs | i2c2k | Micro Controllers | 9 | 7th December 2004 06:11 AM |
| Please help to tell my High power LEDs factory | li-battery | General Electronics Chat | 0 | 9th May 2004 12:37 AM |
