Old 2nd June 2008, 07:58 PM   (permalink)
Default What ICs are useful to have?
Most of the functionality of the 7400 TTL and 4000 CMOS series chips can be replaced with a microcontroller these days. Still, I've found that it's useful to have some of the discrete logic chips lying around for experimentation or quick prototyping. What chips have you found useful, and for what kinds of purposes? What assortment of chips would you recommend the electronics hobbyist to have in their inventory?
pc88 is offline
Old 2nd June 2008, 08:33 PM   (permalink)
It is an endless list and sure to puncture a whole in your pocket, if you want to purchase. Instead you can perhaps simulate and try using suitable software.
Most recent trend appears to use FPGAs and program them to get your logic realization.
yes you can keep few nand gate chips as most circuits can be realised from them. Now a days better go for 74HC4011 in favor of nand gates. You may also store few voltage regulator chips like 78xx and 79xx. the later are -ve voltage regulators.
Regards,
Sarma.
mvs sarma is offline
Old 2nd June 2008, 08:56 PM   (permalink)
One source for cheap usefull microchips that i found is to buy up old test equipment from trift shops, i got some really old cable test equipment and all the ic were mounted in sockets and not directly soldered, and when i was finshed pulling it all apart i had a collection of 74 series chips, i pulled over 100 ICs and it didnt cost me a thing. i pull apart everything before tossing it, you never know what your gonna find. googleing the chips your not sure of is also a big help
josh
joshua17ss2 is offline
Old 2nd June 2008, 09:19 PM   (permalink)
The ones you will use
It all depends on what you are going to do, your area of interest.
3v0 is offline
Old 2nd June 2008, 10:42 PM   (permalink)
Op-amps like the TL08x.
A quad NAND and hex Schmitt trigger are always handy.
Also, even the simplest PICs are still more expensive than the simplist ICs - if all you need is to make an LED flash, a not too accurate 10 or so second delay or a short beep then a 555 is still the way to go as far as I'm concerned.
Screen name: Aloone_Jonez
Hero999 is offline
Old 3rd June 2008, 04:42 AM   (permalink)
not having a source of pics i find it ussefull to have these at stock
4093 40106 4013 4066 4060 4017
LM 358 324 3914 317 327
555
and the 78xx and the 79xx
Robert-Jan
rjvh is offline
Old 3rd June 2008, 06:05 AM   (permalink)
I concur with 78XX, 79XX, 555/556, op-amps such as LM358, a few amplifier ICs like the LM386, and your basic assortment of digital chips. Some suppliers sell kits of ICs, which might be a good option if you don't have many ICs.
If you're in need of a function generator, the XR2206 chip from EXAR is worth considering. It costs about $3-4 USD. With a small handful of component parts and this chip, you can build a nice function generator for $5-$10.
I find 16 pin DIP resistor networks to be useful for keeping a project neat and uncluttered. These are especially good for pull-up/pull-down resistors when working with Micro Controllers.
What are some of the projects that you're interested in?
When I take over, Alcohol, Tobacco and Firearms will be a 24-hour convenience store.
Brian218 is offline
Old 3rd June 2008, 07:07 PM   (permalink)
Im sure alot of people are aware of this but i figure its worth posting for those unaware,
Microchip - Samples Web Site
its the best source of samples i have found, they cover shipping and you can get 2 orders a month,
its great to get a few pics or other ic for a single project or testing purposes.
josh
Old 4th June 2008, 05:28 PM   (permalink)
I used tho think it was handy to have an assortment of logic IC's but these days, I only keep "glue" logic parts on hand and never design with discrete logic function IC's.. SOmetimes, the perfect logic part is just what's called for.. but I find these cases so rare, they are not worth considering. All logic design is done in a PIC, FPGA, CPLD or micro.
Sometimes you need some glue though for level translation or simple functions like AND/OR/INVERT
Optikon is offline
Old 7th June 2008, 12:14 AM   (permalink)
AND gates (for buffering/modulating)
ULN2003 (For switching upto 7 Channels upto 500mA)
MCP4821 (Fast external digital to analogue converter)
Some of my more used IC's besides PIC's
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
Old 7th June 2008, 02:08 AM   (permalink)
Building on what I said earlier.
When you first start the chances of having everything you need on hand for a project is close to zero. Each time you start a project you will need to make a order, get a few extra of the parts that you think you will use again. In time you will build up stock, and you will be able to do some projects without ordering parts.
Common parts like resistors and caps are the execption. I suggest buying a resistor set that makes sense for what you will be dong.
3v0 is offline
Old 7th June 2008, 02:40 AM   (permalink)
I agree with everything 3v0 said.
Additionally, whenever I buy something I know I'll use again, like bypass capacitors, I just buy a metric ton of them. 0.1uF ceramic caps are something you will use a lot of, so buy in bulk - wherever the price break and quantity make sense for you. Sometimes 25, sometimes 100.
speakerguy79 is online now
Old 7th June 2008, 02:45 AM   (permalink)
I just bought another reel of 1000 0.1uF caps, a digital designers best friend next to 1N4148 diodes.
Bill
Smart Kits build Smart People
Old 7th June 2008, 04:59 AM   (permalink)
I have significant quantities of .1uF ceramics in various form factors, 1N4002s, 1N4148s, 1N5819s (to a lesser extent), ~25ea or R,G, and B LEDs, a ton of 330uF 6.3V electrolytics for 5V decoupling caps, a lot of free sample op amps and voltage regulators, a few select values of resistors (100R for current limiting to mosfet gates, 121 ohm specifically for adj regs, 332 ohm for LED's off a 5V supply, 1K and 10K, etc). No more than 100 of anything at the most though. I'm still just a hobbyist (though hopefully not for long).
Old 7th June 2008, 07:09 AM   (permalink)
Diodes are used that commonly in digital circuits?
dknguyen is online now
