| Hi, i have some question on MIDI test, I have a midi out from keyboard, i would like to connect it to a MIDI synthethiser and go to the Amp and speakers. Please correct me if i m wrong and give me some input. 1, i would like to know the MIDI out pin config, pin 1,3 are NC, pin 2 is GND, pin4 current source, pin5 current sink, are they correct? 2, wat kind of output waveform do i expect? i tested on a LED, when the key is pressed the LED blink once but the light is very dim. do i getting the correct signal?the signal seem to be quite low. 3, i was trying to use a 4N32 opto coupler to isolate the signal, but failed, did not receive any signal at the output, the output is going to my MIDI synth, i checked on internet, found that 6N138 time rise/fall is faster, i ordered it. stil waiting... just curious on...the output signal i can get? FYI, i tested on a LED, the LED keep on, i should get a blink on the LED to the midi syth but i did not get the signal, so the speaker don have any sound output. i am using the ATMEL, ATSAM2195 3.3V fixed supply circuit design provided on the datasheet as my MIDI synth. Thanks for help...is my design has any problem? the speakers don work... | |
| The data is pretty standard RS232 serial data, at a specific (non-standard) baud rate, it's pretty easy to do - there are loads of PIC examples on the net, and presumably many AVR ones as well?. An LED is no use to monitor the data, use an oscilloscope. | |
| Hi Nigel, u r a super moderator..! thanks again. i m not using the PIC... i am using an ATSAM2195 chip from Atmel. i tried to check on the oscilloscope...the signal is very unstable from the MIDI out of the keyboard. and i found the LED test to the output, HINTON INSTRUMENTS: Professional MIDI Guide i find the signal is similar to what it was explained on the page. i will try to test it on a 6N138 opto isolator to check at the Vo . Anyone who have the experience on MIDI..please feel free to give advise. Thank you... =) | |
| Hi, i need some helps..i tested on the 6N138 opto isolator, the signal seem right. after i sent the signal to the ATSAM2195 board, the output seem to be quite alots of noises. so i could not hear any sound from the speaker.. please help on me..urgent ! been working on this few days... | |
| DA-15 to DB-9 MIDI | Ebby1 | Electronic Projects Design/Ideas/Reviews | 0 | 17th December 2006 11:10 AM |
| MIDI to CV thats EZ | natbit | Electronic Projects Design/Ideas/Reviews | 0 | 14th September 2004 02:25 AM |
| Test For Inductor Motor :No-Load and Blocked Rotor Test | shermaine | General Electronics Chat | 7 | 28th March 2004 03:06 AM |
| Electronics Pre-Test questions | Mike_07 | General Electronics Chat | 0 | 13th November 2003 03:22 AM |
| Midi cable | Josh | General Electronics Chat | 1 | 2nd July 2003 10:33 AM |
