Old 28th May 2008, 04:07 PM   (permalink)
Default Voltage Stepping Circuit
I'm trying to build a circuit that can produce voltage steps in response to a standard rising or falling trigger signal. For example, on the first trigger signal, the output will be -1.5V and hold there. On the next trigger signal, it'll be 0V and hold. Then 1.5V, 3V, and repeats. -1.5, 0, 1.5, 3, -1.5, 0, 1.5, 3 V etc..
I tried doing it in software using labview but it wasn't responding beyond triggers above 3 kHz. For my application (optics and phase modulation) I need ~ 25 kHz.
Can someone point me in the right direction on how to build such a circuit?
Thank you.
fantasymick is offline
Old 28th May 2008, 04:11 PM   (permalink)
Thank you.
You could do it usng a HEF4017, with outputs into a 'weighted' OPA summer, requires a +/-5V for the OPA power supply.
Do you follow.?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 28th May 2008, 05:56 PM   (permalink)
Do you follow.?
Right. Alternative to the weighted summer would be to drive an analog multiplexor that will switch your input levels (voltage divider / buffered)
Your scanning / switching rate would be determined by the analog mux (25kHz -feasible)
again, +/- supplies needed.
Switching rate with the OPA solution probably determined by slew rate & load of the opamp.
Optikon is offline
Old 30th May 2008, 05:02 AM   (permalink)
Thanks for the suggestions, it's exactly what I need. I think I know what I need to do.
Stepping down 24v to 12v for stepping actuator gints Electronic Projects Design/Ideas/Reviews 4 20th September 2007 03:37 PM
Torque vs angle in stepping motors patroclus General Electronics Chat 3 6th December 2005 02:57 AM
Stepping motors watzmann Robotics Chat 7 27th June 2005 03:41 AM
ULN2803 + Stepping Motor SQLException General Electronics Chat 16 20th January 2005 03:20 PM
What`s the torque of my stepping motors? Charon102 Robotics Chat 6 31st October 2004 07:16 AM
