I recently found some old and newer hard drives too damaged to be repaired for normal PC use now i took one apart for parts such as the motor inside. I know nothing on motor like this. I know about normal motors like with magnets and stuff and how it works but beyaond normal 2 wire stuff i got no clue.
Ill take some pictures but for now let me explain in words. The motor has a 4 wire interface which i soldered 4 wires to a pin header for testing. How do i apply power to it? I tried normal but i think this is like some PWM type thing because i cant apply constant power it stops. But when i put power and then off/on it........... it works. Any suggestions on how i can power this for use? ![]()
My YouTube Videos! My Favorite Stores: dipmicro Electronics SparkFun Electronics Futurlec BG Micro Last edited by AtomSoft; 28th May 2008 at 02:42 PM. |
it is stepper motor. You need to measure resistance between all wires in order to find out what type of stepper motor it is ...
check out : Jones on Stepping Motors the motor I salvaged from old HDD drive is Variable Reluctance Motors and it is as figure 1.1 found here: Jones on Stepping Motor Types ![]() Code:
sequence to drive it:
Winding 1 1001001001001001001001001
Winding 2 0100100100100100100100100
Winding 3 0010010010010010010010010
time --->
most of the HDD's are multiphase motors (5phase) but they are with 5 leads. The one I have (use) is 4 lead just like the one on the pic and it is Variable Reluctance. Pay attention, when you test the motor, - if you start the sequence to slow it will jiggle and not rotate - if you start the sequence to fast if will oscillate and will not turn - this motors have very low torque so in order to achieve rotation (4000 - 7000 rpm) you need to start slow and then increase speed .. I hope this helped
http://www.it4um.com |
In addition to 'arhi's good explanation. If you follow the copper track on the driver pcb, from the 4 pin connector, you should find the motor drive ic. If you are lucky it will have the ic type name on its case. Remove it carefully and you have a ready made driver.. Last edited by ericgibbs; 28th May 2008 at 03:18 PM. |
wow there alot of info there a bit scary... makes me just one to buy one instead lol...
Pins 1 & 4 = 1.3 Ohms 2 & 4 = 2.0 Ohms 3 & 4 = 2.0 Ohms 1 & 3 = 1.1 Ohms 2 & 3 = 2.0 Ohms 1 & 2 = 1.2 Ohms How does this help? Havent really read all on that page yet
My YouTube Videos! My Favorite Stores: dipmicro Electronics SparkFun Electronics Futurlec BG Micro |
St L6278 1.2
B994x0136 Malaysia
It looks like the spindle motor that rotates the platter. A stepper motor would flat out not work for that application.
The schematic diagram in ahri's post is likely correct, but I think this is a 3 phase brushless DC motor. A very different animal from a stepper. It also looks like ST Micro has disavowed all knowledge of this motor control chip. At least nobody answered the guy who posted the question in 2006.
We never have time to do it right; but we always have time to do it over. Last edited by Papabravo; 28th May 2008 at 03:41 PM. |
pin1 is the common lead, as pi1 to pin(2|3|4) is ~1R and between pins 2,3,4 you have 2R so if you look at the schematic, the "winding" resistance is 1R You drive the motor pretty easy .. connect it like this +5V - 100R - pin1 //I drive it without resistor but it should be smart to limit the current RC0 - pin2 RC1 - pin3 RC2 - pin4 and drive: Code:
// config ...
main(){
unsigned short delay, a;
TRISC = 0; //output
delay = 250;
a = 0;
while(1){
PORTC = 0b00000110;
delay_us(delay);
PORTC = 0b00000101;
delay_us(delay);
PORTC = 0b00000011;
delay_us(delay);
if (++a == 0) if (delay>0) delay--;
now, it might happen that still motor "bounces" around, e.g. run back/forth. this mean that you need to get the right "order" of the wind1-3 (not too many combinations, so you can try all 4) you can also try to connect "common" pin to GND and source power from pic, but I'm not sure if pic can give enough current to drive it. as for the motor driver, I managed to salvage bunch of HDD's and I never managed to find any datasheet on the driver from the HDD board as for the "brushless dc" vs "stepper" .. try to rotate the motor with your hand, if you feel the "steps" that's a stepper
Is it your position that a stepper could actually be used for rotating the spindle of a hard drive? You should know that I did spend a few years in the HDD indusry once upon a time.
We never have time to do it right; but we always have time to do it over. Last edited by Papabravo; 28th May 2008 at 04:39 PM. |
As you suggested, it's a DC brushless motor. |
I know you know that and I know I know that, but the question is do the other posters know that?
We never have time to do it right; but we always have time to do it over. |
For some reason i get this error.. the thing is that the file is there im using ver 8 of MPLAB
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F1320 "b.c" -fo="b.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- MPLAB C18 v3.20 (demo) Copyright 1999-2005 Microchip Technology Inc. Days remaining until demo becomes feature limited: 60 C:\PicCode\b\b.c:14:Warning [2058] call of function without prototype C:\PicCode\b\b.c:16:Warning [2058] call of function without prototype C:\PicCode\b\b.c:18:Warning [2058] call of function without prototype Executing: "C:\MCC18\bin\mplink.exe" "C:\MCC18\lkr\18f1320.lkr" "C:\PicCode\b\b.o" "C:\MCC18\lib\c018i.o" /o"b.cof" /M"b.map" /W MPLINK 4.20, Linker Copyright (c) 2008 Microchip Technology Inc. Error - could not find file 'c018i.o'. Errors : 1
Radical left turn! Perhaps a new thread would be in order.
Lefty
Measurement changes behavior |
i get that while compiling the below code (related to this thread)
#include <p18f1320.h>
#include <delays.h>
#pragma config OSC = INTIO1, WDT = OFF, LVP = OFF, DEBUG = ON
void main (void){
TRISA = 0; //output
delay = 250;
a = 0;
while(1){
PORTA = 0b00001100;
delay_us(delay);
PORTA = 0b00001010;
delay_us(delay);
PORTA = 0b00000110;
delay_us(delay);
@Papabravo ah you must be right then
anyhow, however it is called, the code provided should spin it (i tried it few times) p.s. don't get me wrong, I know that mine knowledge of the issue is limited, I'm not being sarcastic - just explaining why I said it is stepper
http://www.it4um.com Last edited by arhi; 29th May 2008 at 03:49 AM. |
| hard drive stepper motor driver | steev | General Electronics Chat | 11 | 10th August 2008 01:42 PM |
| Help with Motor Driver | Souper man | Electronic Projects Design/Ideas/Reviews | 11 | 13th May 2007 07:23 PM |
| Motor Driver | MrMikey83 | General Electronics Chat | 7 | 12th May 2005 08:10 AM |
| hard disk motor cricuits | ranaga | General Electronics Chat | 1 | 6th December 2003 06:54 AM |
| hard disk motor cricuits | ranaga | Robotics Chat | 1 | 26th November 2003 10:05 AM |
