Old 29th May 2008, 09:16 PM   (permalink)
Originally Posted by Leftyretro View Post
I think you are describing the smaller motors used in R/C servos. I was referring to the much larger Brushless DC motors used to power the plane via a propeller.
Brushless Motors for RC Electric Flight from Hobby Lobby!
Lefty
You are correct, I had not considered that a possibility. So do the propellers have a fixed pitch or can you chnage the pitch as well?
We never have time to do it right; but we always have time to do it over.
Papabravo is offline
Old 3rd June 2008, 03:17 PM   (permalink)
Just found a broken printer and took out the stepper from it. Not sure which pin is what tried the resistance thing but i get like:
_Pins_
1 & 2 = 3.0 Ohms
1 & 3 = 0
1 & 4 = 0
2 & 3 = 0
2 & 4 = 0
3 & 4 = 3.0 ohms
Now what?
AtomSoft is offline
Old 3rd June 2008, 03:30 PM   (permalink)
_Pins_
1 & 2 = 3.0 Ohms
1 & 3 = 0
1 & 4 = 0
2 & 3 = 0
2 & 4 = 0
3 & 4 = 3.0 ohms
Now what?
Hi atom,
I dont think you mean 0hm:, is it really infinity.?
If you still have Oshonsoft sim set up, look at the stepper motor module.
Regards
Look here:
http://micromouse.cannock.ac.uk/motors/L297.pdf
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 3rd June 2008, 03:47 PM   (permalink)
EM-2 Linker error: “could not find file ‘c018i.o’”
Enter the proper directory path in Project>Build Options…>Project General tab. Set
the Library Path box to “C:\mcc18\lib”. c018i.o is the start-up library for MPLAB
C18. It sets up the stack, initializes variables, then jumps to main() in the application.
For some reason i get this error.. the thing is that the file is
there im using ver 8 of MPLABError - could not find file 'c018i.o'.
Errors : 1[/code]
bryan is offline
Old 3rd June 2008, 04:40 PM   (permalink)
There is nothing wrong with my path setup i checked multiple times. Everything is setup ok just still get same error.My work around was to set it under:
MENU | Projects -> Build Options -> Project... C18 tab
AtomSoft is offline
Old 3rd June 2008, 04:45 PM   (permalink)
Yeah infinity i suppose i dont know how to make that sign tho lol ∞
Originally Posted by ericgibbs View Post
Hi atom,
Regards
Look here:
AtomSoft is offline
Old 3rd June 2008, 04:51 PM   (permalink)
ok i think i get it now but at what speed should i send a Pulse? or is it trial and error depending on what im trying to do with it?
AtomSoft is offline
Old 4th June 2008, 12:02 AM   (permalink)
Using PORT a 4:1
ok im trying this code and no luck but i feel it trying:
#include <p18f1320.h>
#include <delays.h>
#pragma config OSC = INTIO1, WDT = OFF, LVP = OFF, DEBUG = ON
void main (void){
  TRISA = 0b00000000; //output
  while(1){
     PORTA = 0b00000010;
     Delay10TCYx(1);
     PORTA = 0b00000110;
     Delay10TCYx(1);
     PORTA = 0b00000100;
     Delay10TCYx(1);
     PORTA = 0b00001100;
     Delay10TCYx(1);
     PORTA = 0b00001000;
     Delay10TCYx(1);
     PORTA = 0b00011000;
     Delay10TCYx(1);
     PORTA = 0b00010000;
     Delay10TCYx(1);
     PORTA = 0b00010010;
     Delay10TCYx(1);
AtomSoft is offline
Old 4th June 2008, 01:29 AM   (permalink)
You could send a static 'start up' sequence to the motor to get it started spinning, then using a hall effect sensor or some other feedback to determine the motor spindle speed/phase you could dynamically adjust the speed of the motor until the desired RPM was reached. I'd like to see someone test one of these to destruction, because if you can drive the pulses fast enough and synchronize them the only limit to the speed of the motor is mechanical failure or the torque being insufficient to increase speed at some point.
straight answer, har har."
Sceadwian is offline
Old 4th June 2008, 02:35 AM   (permalink)
How woul di go about sending this startup sequence? speed isnt a factor yet if i cant get it to spin at all lol
AtomSoft is offline
Old 4th June 2008, 08:43 AM   (permalink)
hi atom,
These links will give you an idea of whats required.
Stepper Motor Experiments
Art's Theremin Page: Bipolar Stepper Motor Control Circuit
http://web-ee.com/images/stepper.gif
Check the 'phasing' of the two windings, by using a 5V supply, energise each coil in turn
and observe the direction of rotation of the motor.
A start up sequence is not required, the rate of the pulses to the two coils will determine the motor speed.
Eric
PIC tutorials:
hard drive stepper motor driver steev General Electronics Chat 11 10th August 2008 02:42 PM
Help with Motor Driver Souper man Electronic Projects Design/Ideas/Reviews 11 13th May 2007 08:23 PM
Motor Driver MrMikey83 General Electronics Chat 7 12th May 2005 09:11 AM
hard disk motor cricuits ranaga General Electronics Chat 1 6th December 2003 07:55 AM
hard disk motor cricuits ranaga Robotics Chat 1 26th November 2003 11:06 AM
