Old 28th May 2008, 11:12 AM   (permalink)
Default New to the world of circuitry and I've run into a problem (atari punk console)
I'm trying to construct a stepped tone generator, atari punk console as it's popularly named.
I've found schematics for a circuit consisting of two 555 timers instead of a 556 as many are designed around
I've double-checked and concluded that I've constructed it correctly as according to the schematics (with minute changes). Unfortunately, it doesn't seem to be working.
I have managed to contact the designer of this picture, he said he'd look it over but meanwhile I'd like to have more assistance on any noticeable missing traces you could help me fill in.
I tried getting pictures of my circuit but i don't have much of a camera, just my phone. It doesn't really capture it well enough to make out the circuits. But here is a picture of what I'm working from.
The changes I've made is just there's no switch or led, the location of R2 (I've looked over it and it's constructed the same in the end) and instead of going to an output jack right now, it's connected to a speaker.
I've tested putting in an LED and it works fine but that's not really relevant to my problem I don't think.
Also, the left chip gets really really hot if that's of significance.
Looking forward to your assistance. Thanks in advance.
Narcisto is offline
Old 28th May 2008, 01:25 PM   (permalink)
Are the 555's correctly orientated, that is, is pin#1 as shown by the small round 'grey' dot [ on the drawing]
If you take out IC1 does IC2 still get hot.?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 28th May 2008, 06:20 PM   (permalink)
I do have them oriented correctly, it shows it in the diagram how to position them.
I bought little slots for the chips so i could remove them and such or in case i did do it wrong. Removing the chip i didn't notice any excessive heat in the area.
I'm wondering at this point if any of the components could have become damaged in the construction process.
Narcisto is offline
Old 28th May 2008, 06:23 PM   (permalink)
Do you have a circuit diagram you could post.?
Eric
PIC tutorials:
Old 28th May 2008, 07:04 PM   (permalink)
Does the picture not show up?
Or do you mean like an actual diagram, cause I don't think I know of one for this or generally the dual 555 but there's plenty for 556
Narcisto is offline
Old 28th May 2008, 07:09 PM   (permalink)
The picture shows up OK.
I just dont want to have to draw a circuit from the picture.
I have all the 555's 556 datasheets, thats not the problem.
As you dont have the circuit I'll have to sketch it out.
Eric
PIC tutorials:
Old 28th May 2008, 07:20 PM   (permalink)
Ah I see, convenience. Sorry I don't have it.
Narcisto is offline
Old 28th May 2008, 07:58 PM   (permalink)
Look at this circuit and check it with your picture.
By posting this circuit someone may help with the fault.
The drawing is awful and quick.
The different colours are used to show crossing lines.
Eric
PIC tutorials:
Old 28th May 2008, 08:06 PM   (permalink)
Yikes, things are really switched around between the 2 but I can kinda read it (I'm not familiar with reading diagrams I've basically just thrown myself into this) but I'm catching onto what both say and comparing but I would still need someone else to locate fault. Thank you for your help with this.
Narcisto is offline
Old 29th May 2008, 09:07 AM   (permalink)
This is the circuit drawing, drawn from the picture, its much clearer than that crappy sketch I posted yesterday.
Check the wires and components are connected on YOUR pcb against the drawing.
Use coloured pencils to trace the tracks/connections onto the drawing as you check each connection.
Do you follow.?
Eric
PIC tutorials:
Old 29th May 2008, 09:33 PM   (permalink)
Do you follow.?
I follow it a little, like I said I'm not completely familiar with actual schematics but I'm catching on.
I'm a little confused about the pins in your diagram, the 8 and 4 are the top l/r pins, right? and are they to be oriented with the dots down on both?
This is a diagram to be if it were complete and working, right?
Because I'm more concerned about the integrity of the diagram I followed than my own faults as I have compared a dozen times to be sure.
Sorry for so many questions
Narcisto is offline
Old 30th May 2008, 08:07 AM   (permalink)
Look at the attached drawing.
This layout is standard for all 8 pin DIL ic's
This is the TOP VIEW.
Eric
PIC tutorials:
Old 3rd June 2008, 04:24 AM   (permalink)
ok so, the schematic you posted is a sure working design, correct? i havent had a chance to get to devising a layout but im off for 2 days so i should get some work done.
Narcisto is offline
Old 8th June 2008, 08:42 AM   (permalink)
im currently in the process of making the circuit again.
i drew out your sketch and also found a pic of a layout. i cant find the pics now, but it had both astable and monostable modes so i matched them to the schematic and then made a layout.
now, i thought id try to test it with just the first chip, i get a click when power comes on so it gets through. but no tone or anything continuous. no change with the pot. which im also unsure of if i have it connected properly.
so im curious as to if it should be properly constructed in this half if it should make a sound. the chip gets real hot too, like it did before. dunno if this is normal.
Narcisto is offline
Old 8th June 2008, 08:52 PM   (permalink)
argh i feel im just making the same thing over again
the guy hasnt gotten around to building it himself
anyone have any input on the design? it'd be much appreciated
sorry if i seem pushy
Narcisto is offline
game console Sim Electronic Projects Design/Ideas/Reviews 45 24th November 2007 11:30 PM
Problem with circuitry rumiam Robotics Chat 18 26th April 2007 06:36 PM
video game console colin886 Electronic Projects Design/Ideas/Reviews 1 24th December 2005 06:45 PM
Size of the Atari 2600 cartridges? Electric Rain General Electronics Chat 9 1st June 2005 01:03 PM
An old idea (for the Atari 8 bit computer) David Brown Electronic Projects Design/Ideas/Reviews 3 27th May 2005 09:17 PM
