| What kind of speaker are you using? I can imagine if you use a 8Ohm speaker, the 555 can get hot! Try using a different speaker or use a tranistor to let the speaker sound...
__________________ There are no stupid questions, but PLEASE, think twice before asking them | |
| 8 ohm is fine. Just be sure you use a decoupling capacitor. | |
| hmm, didn't think about the type of speaker i was using. it's from some disassembled harman kardon speakers. i did think to connect the capacitor with it to test. maybe i just need to complete both timer circuits before i get the proper flow. can't seem to find any real distinguishing marks on the speaker except ST 0B3 or something on the back of the magnet. | |
I do know 555's however, and I have serious doubts the layout as shown will ever accomplish much. First, the set-up is backwards, I believe. The monostable is supposed to trigger the astable. According to the layout (a very pretty picture, by the way) and Eric's interpretation of the schematic, this circuit attempts to trigger the mono with the astable. Analyzing the circuit with the 555 Timer Pro computer program, it appears the astable 555 would produce a frequency between 287 Hz at maximum resistance, and 47KHz (20K or so above normal hearing, I believe) with just a small resistance. If that were to make it to the mono, and to the speaker or jack, the tone would sound for 27 milliseconds at the mid-point of the mono's controlling resistor. Don't mean to throw cold water on your project, but I feel you have lots of work left getting it to operate. Hope I'm wrong in my analysis, and I'm here to help if I can. Edit: Also, the LED will never show very brightly at around l.5 mA current.
__________________ All those who believe in psycho kinesis, raise my hand. Last edited by AllVol; 9th June 2008 at 04:07 AM. | ||
| sorry for the lingo term, i realize i really should have used the technical term which is stepped tone generator. it's more commonly made with a 556 but i decided to go for 555 for aesthetic reasons. i probably could save a lot of time and try to convert a 556 shcematic to a dual 555 | |
This often happens with circuits from the web, the 'designer' [ a very loose term] never actually builds the project to check any problems that may exist. Whats more insulting the 'designer' often slaps a copyright notice on the drawing.. don't make me laugh.. Why didnt you use my 'neat' drawing of the original circuit rather than your pencilled hard to read drawing.. Can you explain to an 'old guy' what you expect the output of the circuit to be..??
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 9th June 2008 at 08:00 AM. | ||
My intentions for the output is analog synth basically, i make electronic music. I intend to use it as a tone source into my computer where everything else is made to which i would alter it further. with the building and research of this box I hope to be better grasp the science and try more and larger projects for same string of use. think of it as me trying to build my own moog. while sure the computers job is to do the same thing but i think we can all agree that there is a different kind of essence to using analog hardware. | ||
| threads fallen down some pages i still need to get around figuring a 555 schematic from a 556 circuit | |
| found this diagram ![]() you can see compared to mine the flow is backwards but otherwise the placement is the same. it doesnt have anything past the capacitor for output though so idk if i've got that right. | |
| hi narcisto, The two circuits are almost identical, astable driving a monostable. Which of the two 555's is getting hot and what type of speaker are you using on the output of the monostable.?
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 12:25 PM. | |
| ive been busy lately so i havent been able to get back to building this and i think im gonna need to restart it again, does the direction from the battery matter like you see in my drawings its on the opposite side as what i just posted. it was the astable in both cases. im not sure exactly what type of speaker it is but it was in a preamp harmon/kardon setup, kinda old. ive used connected it to things with a headphone wire before, i thought it'd be usable here. i dont know how many ohms it is | |
Hi, For a test, connect the pin3 of the astable to the pin2 of the monostable with 470R resistor, not just a piece of wire, lets know if it still gets hot..
| hi narcisto, Modify the circuit, add this cap and resistor. Be aware the astable 555 may have already died. EDIT: For the best effect, the output should be connected to an external amplifier.
what is the significance of this change by the way? | ||
| game console | Sim | Electronic Projects Design/Ideas/Reviews | 45 | 24th November 2007 11:30 PM |
| Problem with circuitry | rumiam | Robotics Chat | 18 | 26th April 2007 06:36 PM |
| video game console | colin886 | Electronic Projects Design/Ideas/Reviews | 1 | 24th December 2005 06:45 PM |
| Size of the Atari 2600 cartridges? | Electric Rain | General Electronics Chat | 9 | 1st June 2005 01:03 PM |
| An old idea (for the Atari 8 bit computer) | David Brown | Electronic Projects Design/Ideas/Reviews | 3 | 27th May 2005 09:17 PM |
