Hi All, I was wondering if I could use an NE555 timer along with a transistor to drive a 4 ohm speaker. I dont know much at all in that area, maybe I dont even need a 555 and it can be done with a few transistors and caps. If possible provide a link or draw and post something for me. All I wanna do is drive the speaker via the mic element. Thanks in advance for any help
"Yesterday is History, Tomorrow's a Mystery" |
The max allowed output current from a 555 is only 200mA. If the 555 has a 10V supply then its max current into a 4 ohm speaker will try to be 525mA or 1.9A depending on how the speaker is connected. The 555 will blow up.
A 555 is a timer and an oscillator, not an amplifier. Your mic needs a preamp that is designed for its type and the speaker needs a power amplifier.
Uncle $crooge |
Use a 64
ok, i understand the 555 is only good for 200ma and it did get real hot so what should i use a transistor ? what kind?
A 555 is not a power amplfier. A mic feeds a preamp which amplifies its low level about 30 times, then it feeds a volume control that feeds a power amplifier. The power amplifier drives the speaker.
A 555 makes clicks, buzzes or high frequency whines and its output can be switched ibto the input of the power amplifier.
Uncle $crooge |
| Heating Element | bitem2k | General Electronics Chat | 28 | 25th March 2007 05:00 PM |
| Small Microphone/Speaker Circuit | bluethecow | Electronic Projects Design/Ideas/Reviews | 21 | 2nd August 2006 03:54 AM |
| Speaker Vs Microphone | ghauri | Electronic Projects Design/Ideas/Reviews | 3 | 24th December 2005 05:19 PM |
| Speaker as microphone question... | ken3983 | Electronic Projects Design/Ideas/Reviews | 1 | 31st August 2004 11:23 PM |
| What is a Cyrstal Microphone and Cyrstal Speaker? | Someone Electro | General Electronics Chat | 3 | 15th October 2003 05:12 PM |
