Old 25th May 2008, 07:09 AM   (permalink)
Default high powered led driver circuit...
hey all...
i'm currently trying to figure out a way to use several LEDs as the lighting for my aquarium, but I cannot seem to find an effective power source, or circuit.
the LEDs I found which seem nice enough to use are rated at 3.7v 1A... and I need to use about 7 of them.
they're also rated at 3.5v 700mA, and 3.3v 350mA, but I need a high color temperature which is outputted by the LED when used with high currents.
I may also need a few LEDs with lower current, like the 3.5v 700mA rating, to also have a couple lights at a cooler temperature for plant growth
any ideas?
bassboi is offline
Old 25th May 2008, 07:28 AM   (permalink)
Try google, or searching the forums here. This question has been answered more than once.
straight answer, har har."
Sceadwian is offline
Old 25th May 2008, 11:07 AM   (permalink)
It has been discussed before but finding it can be a pain. I had to look through my attachments to find a suitable thread.
http://www.electro-tech-online.com/g...white-led.html
http://www.electro-tech-online.com/a...nt-current.png
Screen name: Aloone_Jonez
Hero999 is online now
Old 25th May 2008, 12:14 PM   (permalink)
source? any AC/DC source will sufice. they are diodes 1000v 10000v will work as long as you limit he current to a safe dissipation level. ac will work too but remenber to add a diode in series to surpass the reverse voltage breakdown . these diodes can only sustain very low reverse voltage before poof. if you have a low voltage tranformer like for a fone charger you can use it. the LEDS usualy requires 10ma and 2 -3 volts to light up. so no matter what is the voltage output limit the current to 10ma with a resistor. how many can you instal that depends on your tranformaer current capability.ea. 12 v use 4 leds and and 200 ohms you can add more and more of these setup until the tranformer cannot handle the current. do not use 120ac that is dangerous for aquarium. but 12 v will not bother you . and finaly i believe that the light should not be LEDS but ultraviolet to simulate the sun for healthy fishes.
neon is offline
Old 26th May 2008, 12:30 AM   (permalink)
Hello Neon,
You didn't read about the powerful LEDs he has. 1A, not just 10mA.
audioguru is online now
Old 26th May 2008, 03:54 AM   (permalink)
I just turned on a board using 4+4, 1amp LEDs. The current is controlled by a LM3410. I only have 4 LED on now. I will try to get all 8 running soon. The LEDs get very hot. I need to add more heatsinking.
ronsimpson is offline
Old 26th May 2008, 03:31 PM   (permalink)
HV9910 is designed to do just that
Ubergeek63 is offline
Old 3rd June 2008, 04:10 AM   (permalink)
Thanks for the replies, and I took some advice here and I found this:
Circuits for using High Power LED's - Instructables - DIY, How To, tech - Entry
With a couple of questions...
Lets say I'm using like 2 LEDs in a series with this circuit... can I add more in parallel, or would I have to build the circuit again for more LEDs?
bassboi is offline
Old 3rd June 2008, 04:12 AM   (permalink)
I took some advice here, and did a google, and came across this:
I only have one question...
Can I run some LEDs in parallel on this circuit, or would I have to build the circuit again for however many LEDs I need?
bassboi is offline
Old 7th June 2008, 03:22 PM   (permalink)
LEDs each have a slightly different forward voltage. So if they are connected in parallel the one with the lowest voltage will hog most or all of the current and burn out. Then the other LED will have all the current and it will also burn out.
Manufactured products have LEDs in parallel because they measure the voltage and sort the LEDs into groups that have the same voltage.
If a regulated current circuit can operate from a higher voltage then LEDs can be connected to it in series then each LED in the series string receives the same current.
Each string needs its own current regulator.
Launch Controller for high powered rocketry... JonCherba Electronic Projects Design/Ideas/Reviews 9 22nd May 2008 08:47 PM
piezo driver (high intensity) epilot General Electronics Chat 36 8th February 2008 07:32 AM
High side driver - how to use... Armagdn03 Electronic Projects Design/Ideas/Reviews 3 11th June 2007 06:59 PM
High side PMOS driver Oznog General Electronics Chat 4 27th May 2004 08:24 AM
any bdy having a schematic of a high powered stereo amp Raheem Electronic Projects Design/Ideas/Reviews 0 30th July 2003 05:01 PM
