Hi all newbie here. Been lurking around here for a while and I must say alot of knowledgeable people here. All this reading has inspired me to start my first project. I'm looking to build a little sound device. Basically I have music in mp3 format. I would to make a device which at the touch of a button will play the mp3 file. I was told by someone that in order to burn mp3 files to an eprom chip the data must be in binary or hex format. Is this true? If so, what program do I use to convert mp3 or wav files to binary or hex format so I can burn to a chip? Any diagrams available for this?
If you want to use the MP3 format you need a MP3 player which is quite complex. You can buy a little card from futurlec that will play the music. All you need to do is interface to it.
If you do not need MP3 quality you can use one of several voice recording chips on the market.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) |
All the sound effects I have are already in mp3 or wav format and are really good quality. I'm not sure how to go about accomplishing my goal which is to have a device where I push a button and the sound files play.
The card from futurlec looks really good. How would I store my sound effect to this device? Does it come with software? I guess the other possiblity is to burn these files to a chip. How can I accomplish this if my source files are currently mp3 or wav files and need to be burned to a chip? Thank you for your help. |
You could do this with the board or chips I suggested in my first post. If you must have mp3 quality it will have to be the board. To use the board you are going to need to know more them a little about micro controllers.
This is not a good first project. Go to your local electronics store and see if you can find a small MP3 player that can be setup to do what you need.
If I go the chip route will I have to convert the mp3 / wav files to binary or hex before burning to chip?
Do you have any microcontroller programming experience? What is your level of electronic experience?
My experience is in the IT field. My friend is my electronic guru but he has never worked with an eprom programmer.
Neither he or I having any knowledge on burning chips. I have been told by someone that I will need to convert the mp3 or wav files to binary or hex files before I can burn to chip. Is this true? If so, which software would do that? Thanks. |
It's a very advanced project and an EPROM programmer is so 1990. You'll need some mad skills before you even attempt such a project.
Read this, it tells you how build an MP3 player. MP3 Player, How To Use The STA013 MP3 Decoder Chip |
Radio shack used to sell a voice chip that you could control with switches instead of a mico controller. Do not know what they are currently selling. I think the card from futurlec is just the VLSI VS1002 MP3 Chip and the discrete parts it needs to work. You still have to use a microcontroller to store the sounds files and stream them to the board.
"You still have to use a microcontroller to store the sounds files and stream them to the board."
The sound files I have are in mp3 / wav format. Will these files need to be converted to binary / hex before burning to chip or will I just burn then to chip in its current format that being mp3/wav format? Thanks Last edited by Johnny Diaz; 25th May 2008 at 02:18 AM. |
What program would I use to let the chip record while playing the mp3 files?
Thanks Last edited by Johnny Diaz; 25th May 2008 at 03:27 AM. |
The chip plays MP3 files in their native format.
Thank You 3v0 and blueroomelectronics for all your help. Your right I definately need to be reading data sheets.
How is the sound quality of the voice chip recorder? |
| I have a problem in my sound light device: | Rami00972 | Electronic Projects Design/Ideas/Reviews | 12 | 30th August 2007 02:20 PM |
| Sound Activated Device (Desperately need help) | Flamacue | Electronic Projects Design/Ideas/Reviews | 3 | 20th May 2006 02:10 AM |
| help building a sound recorder | blasito1973 | Electronic Projects Design/Ideas/Reviews | 1 | 8th July 2004 07:27 AM |
| Sound/Noise Canceling Device | IONtheFROG | Electronic Projects Design/Ideas/Reviews | 5 | 6th November 2003 05:44 PM |
| building a "sound beam" device | fadY | Electronic Projects Design/Ideas/Reviews | 2 | 26th March 2003 02:14 PM |
