hi everyone im sorta stuck i have an idea to build a LED lantern because i wanna turn the nights into day, im planing on using 50 (could use more) white 50,000 mcd led wich i found on ebay but i dont no how to creat the circuit and dont no what other components i would need to use i have googled alot but couldnt find anything so i was wondering if anyone would like to help me out in designing the circuit
thank you |
Rather than using an insanely large number of LEDs, use a single power emitter, like the one linked below.
rswww.com |* LXHL-MWEC, Lumileds Lighting, Wht enhanced low dome lens star LED,1W, 467-7503 The simplest way of getting the LED to light is to use a series resistor. The forumula to calculate the value can be found using Google. LED series resistor - Google Search Of course this isn't the most efficient way of powering an LED, especially at higher power levels where a switching regulator is more suitable.
LED series parallel array wizard
This should help you wire up your LEDs. Your 50,000 mcd LEDs probably have a narrow angle, maybe in the 20 degree range. Kind of directional, also at 12 volts, you'll be using around 350 ma, about the same as a 1 watt emitter, which usually have angle of 120 degree for similar brightness. Kind of depends on what sort of torch you want. Your LEDs will be more of a tight beam, like a spotlight, a single 1 watt emitter will be more like a lantern. |
thanx alot with those links guys but with this circuit board would i need any capacitors or other diodes apart from the LED
Just an LED and resistor will do.
they are really bright, i used them for a lighting display and controlled them with a pwm signal and a fet
V=IR Period. |
| LED torch/spotlight | Da_vinci_cod | Electronic Projects Design/Ideas/Reviews | 11 | 3rd March 2008 10:42 PM |
| Wind-up LED Torch! | HarveyH42 | General Electronics Chat | 26 | 25th June 2007 12:31 PM |
| Personal Alarm/Torch Project.. help? | big k | Electronic Projects Design/Ideas/Reviews | 5 | 19th June 2005 06:32 PM |
| Mag switch for underwater torch | DanL | Electronic Projects Design/Ideas/Reviews | 0 | 22nd August 2004 05:54 PM |
| Looking for Lazer Torch | eclvk | Datasheet/Parts Requests | 1 | 30th June 2003 05:19 AM |
