| Hey, I need help with my circuit. I have used a 555 timer to create a time delay before activating a relay. That is all fine, But I also created a relay latch. (When relay is activated, even if u reset the activation switch, the output remains on such as an led, until a second button is pressed to reset the circuit. Im having trouble comining them. I can make the delay, and the latch, but they need to work together. Heres what i want the conclusion result to be. 1) When a switch is activated: the 555 timer waits 3 seconds and then activates the relay. 2) When the relay activates, the activation switch must be reset, however in order to reset the circuit and shut off the relays output, another switch must be pressed. If you could give me some help on doing this that would be great. | |
| I think this with do the job for you. The relay will stay energized until the N/C push button is depressed then the relay will deenergize. See attached diagram.
__________________ The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. | |
| Relay delay circuit... | Rescue1 | Electronic Projects Design/Ideas/Reviews | 2 | 31st August 2007 06:32 PM |
| dsPIC Latch Question | burg | Micro Controllers | 2 | 14th August 2007 09:08 PM |
| Delay Relay | BlackSportD | General Electronics Chat | 7 | 11th July 2007 08:07 PM |
| Relay delay circuit - please help. | Odysseas | Electronic Projects Design/Ideas/Reviews | 7 | 14th November 2006 11:13 PM |
| Solid State alternative to relay, low latch V | LiquidKernel | General Electronics Chat | 2 | 24th March 2004 02:02 AM |
