Old 20th May 2008, 01:09 AM   (permalink)
Default Voltage to digital reading
Hi all, my first post.
I've got a project I am working on which measures the water level in a tank by using a piezo pressure sensor (Honeywell 24PCBFA1D http://docs-asia.electrocomponents.c...6b80026163.pdf ) connected to an open ended tube inserted in to the tank. I calculated that the maximum pressure for 3m of water is about 4.5 psi so I got this 5psi max component.
The component measures pressure by a range of voltages, from what I can see. 85mV to 145mV, where 85mv is no pressure and 145mV is 5psi.
What I want to do is have some indication (LED's or Computer interface) as to the value. How do I go about converting say 100mV to a digital value I can do something with? E.g. light up the first 3 of 10 LED's to show the tank is 1/4 full. Or take the raw 100mv value in to the computer and calculate the height of water in the tank.
Thanks heaps,
Craig
richacm is offline
Old 20th May 2008, 06:32 PM   (permalink)
you could start with a cheap multimeter, I can can get one for $6, rip it apart and remount it in another box. If re-scaling is the problem ie you want 100mV (or 100 somethings) to represent 100% full you could do it with an op-amp(even a 741).
Super_voip is offline
Old 20th May 2008, 06:43 PM   (permalink)
If you amplify the signal, you can configure a LM3914 LED driver to display the 'depth' on a LED bar.
Get the LM3914 datasheet from DatasheetArchive :: Free Datasheet Search Engine :: Electronic Components
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 20th May 2008, 08:54 PM   (permalink)
Thanks for the input. I think that LM3914 will work a treat in conjunction with that Op-Amp....just need to figure out how to convert the 100mV to a reading within the range for the LM3914.
That multimeter idea is interesting also, what components does that use?
richacm is offline
Old 21st May 2008, 06:41 AM   (permalink)
After a little amplification, the LM3914 resistor values can be configured to remove that 'bottom end' offset voltage of 85mV.
The LM3914 LED's will show 'zero' [say LED #1] and the 'top end' 145mV should light LED #10
Eric
PIC tutorials:
The Oscilloscope ElectroMaster Electronic Theory 12 3rd February 2008 01:45 PM
Voltage ElectroMaster Electronic Theory 44 8th August 2007 05:35 PM
Voltage Clamp ThirtyTwo General Electronics Chat 41 11th August 2006 04:05 PM
convertion of acvoltage to high dcvoltage panchumarthy Electronic Projects Design/Ideas/Reviews 8 12th December 2003 01:35 PM
resistor andrew8485 General Electronics Chat 10 27th November 2003 03:23 AM
