Old 19th May 2008, 10:20 AM   (permalink)
Default NiMH battery charger with charging regulator
hi
i need help with a battery charger for a NiMH battery pack consisting of three AAA batteries so 3.6v.
the charger has to be as small as possible and it sits a meter away from the batteries to be charged.
the batteries will be attached to the charger most of the time so there needs to be some kind of safety regulator which prevents them from overcharging.
thank you for suggestions
m
moinmoin is offline   Reply With Quote
Old 19th May 2008, 11:07 AM   (permalink)
You could try one of TIs BQ2000 familly
Ubergeek63 is offline   Reply With Quote
Old 19th May 2008, 03:14 PM   (permalink)
hey
thanks for that ...
what are you suggesting exactly ?
i'm not very familiar with electronics (just starting)
i looked it up on google but don't get what it actually is ...a regulator or charger with regulator ...or....?
could you please explain more in detail what i have to do..
thanks for further advise
m
Old 19th May 2008, 03:45 PM   (permalink)
the BQ2000 itself is a fast charge switching chip.
http://focus.ti.com/lit/ds/symlink/bq2000.pdf
The BQ2002 is meant for a current limited supply that it just turns on and off:
http://focus.ti.com/lit/ds/symlink/bq2002f.pdf
The BQ2057 is a linear:
http://focus.ti.com/lit/ds/symlink/bq2057c.pdf
Old 20th May 2008, 07:18 PM   (permalink)
hi Ubergeek63
thanks for this links.
i think the bq 2000 is exactly what i'm looking for.
is it possible to just use the Peak Voltage Option (without temp. control etc)?
"Peak Voltage (NiCd, NiMH)
The bq2000 uses a peak-voltage detection (PVD) scheme
to terminate fast charge for NiCd and NiMH batteries.
The bq2000 continuously samples the voltage on the
BAT pin, representing the battery voltage, and triggers
the peak detection feature if this value falls below the
maximum sampled value by as much as 3.8mV (PVD).
As shown in Figure 6, a resistor voltage-divider between
the battery pack’s positive terminal and VSS scales the
battery voltage measured at pin BAT." page 5 from the bq 2000 link you've send
there is one more thing which i forgot to mention: the +/- cable coming from the charger should maintain the power (3.6v) while charging so the object (in this case an led light) can still be operated while being charged.
is the peak voltager charging regulator still able to detect the battery status in this case?
thanks for advise, it is much appreciated as i am still a beginner in electronics.
m
Old 21st May 2008, 01:06 AM   (permalink)
A "3.6V" Ni-MH battery reaches 4.5V or more when it is quickly and is fully charged.
A few other battery charger circuits can power a device while it charges its battery.
Old 21st May 2008, 01:19 AM   (permalink)
As the circuit works as a current source, it really does not care if you are running the load at the same time. I, as a matter of fact, do that myself.
The trick is that if you are fast charging the battery the charge rate will be reduced by the load current. This works fine if your load current is less than half the charge current. Since it is based on peak voltage it will still terminate the charge cycle reliably.
Old 21st May 2008, 11:04 AM   (permalink)
great!
what kind of resistors do i need to create this voltage divider?
do you know a more specific circuit which explains in detail what i have to do with the bq 2000 ic to work? i need a description for stupid:-)
thanks for all the advise so far !!!
m
Old 13th July 2008, 07:46 AM   (permalink)
Smile how to control the current in bq2002f with circuit diagram
Originally Posted by moinmoin View Post
hi
m
jai_prakashmurugan is offline   Reply With Quote
Old 21st July 2008, 02:52 AM   (permalink)
Default I sugesst a circuit of our design house
please see the attached file.It's a MCU controlled charging circuit.The determination:negative delt V, Zero delt v,deltT/delt t,MAX deltT,Tmax,Vmax,MaXtime.
jason@gamil.com
ghx420 is offline   Reply With Quote
regarding NiMH battery charger using LM317 mabauti General Electronics Chat 16 15th March 2007 04:14 AM
NiMH battery charger MrMikey83 Electronic Projects Design/Ideas/Reviews 3 19th January 2005 04:43 PM
constant voltage, constant current Lead Acid Battery Charger Erwin_Macaraig Micro Controllers 0 4th January 2005 09:35 PM
Real NiMH Battery testing / charging williB Electronic Projects Design/Ideas/Reviews 0 21st October 2004 08:09 PM
To design and build a 6V NiMH 9000mAh battery charger kiwibikey Electronic Projects Design/Ideas/Reviews 1 28th March 2004 05:57 PM
