Old 18th May 2008, 01:30 PM   (permalink)
Default Usb <-> Rs485
Hi
Is there anybody that has som schematics for a USB to RS485 converter??
Simplicity rules
Good enought - its perfect ??
2 Gig of free online backup space
Are you a Chemist?
Kryten is offline   Reply With Quote
Old 18th May 2008, 01:37 PM   (permalink)
No but I would take PIC18F2455 and MAX485, add crystal, connectors, a few capacitors and there you have an adapter. All that it will need is a firmware for the microcontroller ...
You can have a look at the Unicorn kit from blueroomelectronics
petrv is offline   Reply With Quote
Old 18th May 2008, 01:39 PM   (permalink)
Hmm sounds like a big box
Can it run on USB power?
Simplicity rules
Are you a Chemist?
Old 18th May 2008, 01:41 PM   (permalink)
if you use the SMD versions of the chips it won't be big. I don't see a problem running that on USB power.
Old 18th May 2008, 01:43 PM   (permalink)
Cool Im looking in to it as we speak
Simplicity rules
Are you a Chemist?
Old 18th May 2008, 01:50 PM   (permalink)
The FT232R has the schematic for a USB to RS485 converter in its datasheet.
FT232R
Bill
Smart Kits build Smart People
Old 18th May 2008, 02:02 PM   (permalink)
They dont provied samples
Simplicity rules
Are you a Chemist?
Old 18th May 2008, 02:17 PM   (permalink)
Hi Bill,
I don't know how I end up advertising your kits again ...
I was thinking about the FTDI chip as well but personally I prefer the PIC.
Both solutions have their advantages and disadvantages of course.
Petr
Old 18th May 2008, 02:43 PM   (permalink)
Hey I always appreciate the plug I've used the FT232R and it's a nice chip. Would make an excellent USB to RS485 kit.
Bill
Old 18th May 2008, 05:27 PM   (permalink)
I used to use FTDI chips all the time .. and recently I decided to stop. I stopped when I found out that locally I can get FTDI chip for 8E and PIC18F4550 for under 7E .. so that simple truth removed FTDI chips from my order list. There is nothing FTDI can do that 18f4550 cannot (except, ok, ftdi is much smaller and use less power)
http://www.it4um.com
arhi is offline   Reply With Quote
Old 18th May 2008, 05:51 PM   (permalink)
FT232R
Pros no firmware or crystal needed, low power.
PIC18F2550 / 4550
Pros DIP package (if you don't want to solder a SOIC), and you get a nice microcontroller thrown in. I did find a FT232 emulator (firmware) on Xiaofan Chen's site.
Xiaofan's Blog: USB
Bill
Old 18th May 2008, 05:59 PM   (permalink)
I'd like to add that even if you do want to use SMD parts SOIC package (PIC18F2455/2550) is much easier to solder than FTDI chip in SSOP package, QFN is even more manual soldering unfriendly (I assume you don't have your own reflow owen ...)
Old 18th May 2008, 06:11 PM   (permalink)
@blueroomelectronics
I agree with pro's and con's but, how often do you make usb device without uC .. 90% of devices I made used FTDI in cooperation with uC on board. I usually do not pay attention on the cost, but when I noted that instead FTDI I can put 18f4550 I just stopped..
I never tried to manually solder FTDI what I do is I put solder on pcb, glue the FTDI on top of that (using flux as a glue, as it is sticky while hot) and then I put it in normal house oven for few minutes... never failed
Old 18th May 2008, 06:26 PM   (permalink)
I'm not a fan of soldering SOIC and such myself, the best solution I've found is the Schmartboard system. Soldered a TQFP with it just fine.
Bill
Old 19th May 2008, 01:33 AM   (permalink)
Try writing to a thumb drive with a 4550...
Ubergeek63 is online now   Reply With Quote
interfacing ibutton to PC using USB konzen General Electronics Chat 26 13th May 2008 10:31 AM
USB Power hack with DC/DC Converter - am I crazy? chconnor Electronic Projects Design/Ideas/Reviews 14 8th March 2008 09:12 PM
Help needed developing USB peripheral using HID class Adester Micro Controllers 4 22nd November 2007 02:42 PM
com -> usb converter zoharl Micro Controllers 13 26th October 2007 08:07 AM
usb interfacing problems for a waveform generator simonharvey Electronic Projects Design/Ideas/Reviews 0 26th September 2007 11:31 PM
