Old 15th May 2008, 06:36 PM   #1
Default Guitar pedal Op Amp switching
Okay so I see all these kits online for switching the Op-Amp and a couple of resistors in the Tube Screamer and Boss SD-1 distortion pedal and they usually come with an IC socket to make switching between the 2 or more chips easier. I was wondering if there was a way to switch between 2 or more Op-Amps (say the 4558 and all its variants and the 75558 or any of the others that are similar) other than using an 8PDT switch? The 8PDT are kinda bulky and expensive. My question is could you switch just the power (as in a simple DPDT)from one chip to another and still have the other 6 pins(from both op amps) wired without it affecting sound/performance or just making a small campfire in the practice room?
Dr_Satan is offline
Old 15th May 2008, 07:09 PM   #2
The best way would likely be to built separate circuits for each op amp, power them all with their inputs in parallel, and just switch the output signals with a single-pole, multi-throw switch.
crutschow is offline
Old 19th May 2008, 01:24 AM   #3
Default thank you crutschow
thanx for the input, i was doing some research for yet another stompbox project and stumbled across the information i was looking for. and it is exactly as you said. here's the link if you or anyone is interested in seeing how it is done.
Stacked Op-Amp Switcing
Dr_Satan is offline
amp, guitar, pedal, switching
Built an effects pedal for my guitar. It doesnt work :( bboy_jon Electronic Projects Design/Ideas/Reviews 25 8th May 2008 03:14 PM
guitar amp, where to start jay543_uk Electronic Projects Design/Ideas/Reviews 4 12th February 2008 11:18 PM
Simple Guitar Distortion Pedal TrevorP Electronic Projects Design/Ideas/Reviews 20 12th December 2007 05:05 AM
Zero Signal audio switching gtrdude General Electronics Chat 12 12th November 2006 08:28 PM
Acoustic guitar amp VS Guitar amp Johnson777717 Electronic Projects Design/Ideas/Reviews 2 3rd February 2004 03:16 AM
