+ Reply to Thread
Results 1 to 4 of 4
Thread: a question on norton method..
  1. #1
    Banned transgalactic Bad transgalactic Bad transgalactic Bad
    Join Date
    Apr 2008
    Posts
    240
    Default a question on norton method..
    http://img391.imageshack.us/my.php?image=img8855ew6.jpg
    why "I" is negative??
    i know that KCL says that the sum of the currents that goes in
    equals the sum of the currents that goes out
    here i dont know what current goes into the node
    and what current goes out??
    i dont know how you decided the direction of each current
    i am new to this stuff
    and i think that the "I" current is pointed up
    so it goes into the node
    the second current the goes threw "R1" also come into the node
    because the currect goes from the plus of the battery to minus of the battery
    where did i go wrong??
    i cant see the conventions here
    i cant see how the currents flow using these conventions
    in what case we have e-v and in what v-e
  2. #2
    Diver300 Excellent Diver300 Excellent Diver300 Excellent Diver300 Excellent
    Join Date
    Oct 2007
    Location
    England
    Posts
    1,096
    In this case, all the currents are taken as the currents leaving the node.
    They all add up to zero. That means some will be negative.
    The current leaving the node to the battery via R1 is (e-V)/R1
    (this could be negative or positive, depending on lots of things)
    The current leaving the node through R2 is e/R2
    (This will be positive)
    The current leaving the node through the current souce is -I
    (This will be negative)
    I hope this helps.
  3. #3
    Join Date
    Apr 2008
    Posts
    240
    Default questions regarding this norton article..
    Norton's Theorem : DC NETWORK ANALYSIS
    in this article they present only one resistor between the lines
    i can put many resistor between the lines
    how do i recognize the load resistor??
    after that they calculated they said that there is a total current 14A
    i cant understand how did they get this number
    and how did they decided that the norton equivalent must be 0.8????
  4. #4
    jacob.zurasky Newbie
    Join Date
    May 2006
    Posts
    44
    The Norton current is calculated by replacing the load with a short circuit and then figuring out how much current flows through the short circuit. There are two loops in the figure shown with the short. The total voltage drop around the loop must be equal to zero. Each loop only has two components, a source and a resistor. So all the voltage provided by the source only has one component to drop all its voltage across. So each resistor sees the full sources voltage across it. So VR1 = 28v and VR3 = 7v. Then using I=V/R, you can calculate the current through each resistor. IR1 = 28v / 4 = 7A, and IR3 = 7v / 1 = 7A.
    Then, using KCL, the sum of currents entering a node must equal the sum of the currents leaving the node. There are 14A leaving the node, so there also must be 14A entering the node.
    The 0.8 ohms comes from calculating the circuit's resistance as seen by the load. Use Superposition and remove the sources, voltage sources become shorts, current sources become open circuits. The resulting circuit is only 2 resistors in parallel. (1*4)/(1+4) = 0.8 ohms.
    Another good way to find the Norton Resistance is to remove the load. Calculate the voltage open circuit...Voc. Then calculate current shorted across the load connections...Isc. Rt = Rn = Voc/Isc. Voltage open circuit can be found by using voltage division. The voltage across R1 and R3 is 28-7=21v. The voltage across R1 can be found by 21v * (1/(1+4)) = 4.2v. So the total voltage across the load connections equals 4.2v + 7v = 11.2v.
    Rt = Rn = (11.2v / 14A) = 0.8 ohms
    -Jacob
+ Reply to Thread
  1. third method of SSB generation (weaver's method)
    By samcheetah in forum General Electronics Chat
    Latest: 9th August 2009, 05:04 PM
  2. Capacitor Charge/Discharge question
    By ThermalRunaway in forum General Electronics Chat
    Latest: 12th August 2008, 04:48 PM
  3. Toner Transfer method question.
    By HarveyH42 in forum Chit-Chat
    Latest: 4th March 2007, 05:16 PM
  4. High speed data logging question
    By cubdh23 in forum Micro Controllers
    Latest: 19th August 2004, 11:54 AM
  5. Data Logging question with high speed!!!!
    By cubdh23 in forum General Electronics Chat
    Latest: 16th August 2004, 06:33 PM
Tags for this Thread
