Old 15th May 2008, 12:18 PM   (permalink)
Default LCD pinout
Hi!
I hav this LCD. I don't know the manufacturer and pinout, if its is HD44780-based. How do I know? I saw this name on the back, P16100. Please help!
timex83 is offline
Old 15th May 2008, 01:08 PM   (permalink)
Originally Posted by timex83
Hi!
Please post a picture of pcb.
The HD44780 is not the problem its the layout of the pins on the pcb.
Are there 14 pins or 16 pins, one end should have the number '1' near a wiring connection.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 16th May 2008, 07:58 AM   (permalink)
Default Pics of PCB
Thanks for your reply, Eric. The LCD has 16 pins and yes one end has the number "1". Below are the pics.
timex83 is offline
Old 16th May 2008, 09:22 AM   (permalink)
The first 14 pins are wired as the attached diagram
Also this link will be useful.
How to control a HD44780-based Character-LCD
Do you follow.?
Eric
PIC tutorials:
Old 16th May 2008, 12:25 PM   (permalink)
Do you follow.?
Thanks, Eric. What is d function of pins 15 & 16? Is it 4 backlight?
timex83 is offline
Old 17th May 2008, 08:20 AM   (permalink)
I am not sure what pins 15/15 do on that LCD, as I dont know the type of pcb/manufacturer.
The set of solder pads at the other short edge of the pcb are most likely to be for a LED backlight.
I'll look around for info on pins 15/16.
EDIT:
Found a printed document, to faint to copy.!
Says pin 15 is LED+ and pin 16 is LED-
BUT, if you look at the printing on the backside of you pcb, its marked +K, +A at one end and -K and -A.???
I think your LCD is manufactured by GOLONE China.maybe a SGL-VCM1602A
Eric
PIC tutorials:
Old 19th May 2008, 07:33 PM   (permalink)
Thanks 4 the information u've provided
timex83 is offline
Old 20th May 2008, 01:03 AM   (permalink)
... and here follows the translation: "K" means "Kathode" --> English "cathode" and "A" means "Anode" --> English "anode".
If it's a German design manufactured in China the pin describtions were obviously misprinted. They should be -K and +A.
The backlights of LC-displays vary in current flow (commonly 50mA). Use 100Ohms in series and connect to VCC and GND. If connected reversely the display stays dark, the other way it will light.
Hans
Boncuk is offline
Old 20th May 2008, 11:14 AM   (permalink)
pin1 VCC -5V
2. Gnd
3. Vss to adjust the contrast of LCD
4. RS (register select)
5. RW
6. ENable
pin 7 to 14 data pins D0 to D7
pin 15 gnd
pin 16 VCC for backlight
shivaramcunchala is offline
Old 20th May 2008, 11:37 AM   (permalink)
The pin numbers , though 1 to 14 or 1 to 16, are not in the same order in few makes of LCDs. I saw one unit by M/s XIAMEN OCULAR model GDM1602M, where in the pins are on the top right instead of standard TOP left and the order is 16, 15, 1, 2,...... 14.
@ Sivaram... please re-check the definitions of pins 15 and 16.
Regards,
Sarma.
mvs sarma is online now
LCD 2x16 Demo for the Unicorn (18F4550) blueroomelectronics Micro Controllers 21 31st October 2008 05:17 PM
LCD Bargraph (fuel gauge) karenhornby Micro Controllers 10 10th April 2008 06:20 PM
Atmel, assembly:displaying on lcd Haidy Micro Controllers 13 11th February 2008 09:13 PM
HD44780 LCD operation ssylee Micro Controllers 25 15th December 2007 01:52 AM
PIC16F628A LCD problems. HerbertMunch Micro Controllers 17 2nd October 2007 10:20 AM
