Hi there. i'm brand new here, and im sorry to say my fist post is asking for your help. Im new to electronics (im only 16 ) so please excuse my stupidity. Im trying to build a device with the following specs and was looking for some advice really: counter to count between +40/-40 and have a chip that outputs to a vibrator when the counter is > a specified number. I need two seperate inputs for +1 and -1 aswell as a third button to reset the counter to 0. I dont necessarily need to display the count value, but i would be cool if i could. Or if it would be easier, have the device reset to -12 (ish) and then have it vibrate when the counter reaches 0. So far ive got word that im looking @ either
but im really unsure how to implement either of these chips into a working peice of electronix. A little digging around on the internet has led me to believe i will need to use a PIC to do the when counter > x part. So im really asking, am i heading on the right tracks here? and do you have any resources with examples of projects of this nature? could anyone help me build something like this step-by-step? i know that you time is valuable but i would be eternally grateful if you could help me out! thanks | |
| | #2 | |
If its a decimal count to +40 then a 74LS192 up/dwn 'decade' counter would be my suggestion, especially if you want to display the counter in the future. When you say, +/-40 counters, do you mean a count upto a maximum of 40 and the ability to down count this counter to zero.? Or are you saying two separate counters, one counting up and the othe counting down.??? which dosn't sound right to me. What range of specified 'vibrate' now values do you want to cover.? You could do this project with logic ic's [74lS192] or a small PIC. If you go the PIC route, you will have to write the program and also have the equipment to program the PIC.. What do you think.?
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
| | #3 | |||
so if it was at zero and i pressed the -1 button it would count down 1 to -1 and then if i pressed it again it would go to -2, then pressing the +1 button would take it back to -1. Quote:
thanks for he;lping me clear that up a bit | ||||
| | #4 | |
Does this help.?
it helps a lot, thankyou! wondering how i should wire the 4 x LS192 ? also would i need a specific logic gate for this or are they programmble chips? thanks alot. | |
| | #6 | |
Look at this initial drawing. It uses two 74LS192 decade counters. Pushing the LOAD switch, preloads the counters with 40 decimal. The +1 and -1 increment switches count up from 40 or down from 40. The extra logic on the outputs of the LS192 would have to detect when, count is 28 or less OR count is 52 or greater. On detecting these limits a latch would be set and the 'vibs' activated. Is this what you are looking for.? Whats the purpose of this project..?
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 12:25 PM. | ||
| | #7 | |
Its going to be for a board game thing that one of my mates is making in his graphics GCSE. I said i would try and help him with it because im really interested in getting good at electronics. | ||
| >, counter, vibrate |
| Dual counter | bananasiong | Micro Controllers | 45 | 24th March 2007 03:49 AM |
| How we can do it in Assembly..Help Needed | Ayne | Micro Controllers | 37 | 29th December 2006 06:49 PM |
| Input Counter Pic16F84A (Code problems) | loco | Micro Controllers | 4 | 26th September 2006 02:19 PM |
| [help] Power consumption issue on bullet counter project * | Lanzer | Electronic Projects Design/Ideas/Reviews | 13 | 26th August 2005 07:06 AM |
| Crude assembly counter | Mark Lazarides | Micro Controllers | 5 | 28th February 2004 08:22 PM |
