| New Member | Hello, I wish to make a circuit that can be used to control 3-5 lights in accordance with the rythm of some audio signal fed to it. I have heard of some music ICs but doesnt know their part no. nor their function. Please help.. Last edited by explorerbaba; 13th May 2008 at 08:16 PM. |
| Experienced Member | Here's an idea for the lighting side http://www.national.com/pf/LP/LP3943.html Not a very friendly package to solder. |
| Experienced Member | Don't use that impossible to solder IC and drive it with a computer, use an LM3915 instead. It has ordinary pins that mount through holes on a circuit board or on stripboard. Its datasheet shows a peak detector circuit that holds the peak level for a moment long enogh to see it. It drives up to 10 LEDs and has built-in current regulation for the LEDs.
__________________ Uncle $crooge |
| Experienced Member | Quote:
| Experienced Member | explorerbaba dosn't mention what size of lights. I recall in the mid-late 60's we built simple color organs using scr's very simple circuit. I recall powering 150w colored bulbs. One bulb per scr. am sure if this is what you want then a search engine. As for dividing the frequencies into 3 sections then filters. The color organ had adjustable filters. |
| New Member | Thanks all for replying. I plan to light three 100W bulbs. Please post the circuit using LM3915. |
| Experienced Member | An LM3915 is designed to drive low voltage LEDs not high power light bulbs. You need a high power color organ circuit. Light bulbs are slow to turn off so they might not need peak detector circuits.
| Experienced Member | most are really simple BUT you must remember that it is running at a lethal 110v the last one is using a lm3915 but as Audioguru pointed out it has a slim chance of working. http://www3.telus.net/chemelec/Proje...olor-Organ.htm http://home.maine.rr.com/randylinscott/jan99.html http://www.aaroncake.net/circuits/organ1.gif http://www.discovercircuits.com/C/color-org.htm http://www.national.com/mpf/LM/LM3915.html |
| Programmable Controller for Tiny led Lights | stuben | General Electronics Chat | 6 | 20th March 2008 09:53 PM |
| Creating Critter lights | Highwrath | Electronic Projects Design/Ideas/Reviews | 13 | 22nd June 2007 03:23 PM |
| Problem with Neon underbody lights and car dome light | rvk2 | General Electronics Chat | 4 | 3rd January 2007 07:22 PM |
| controller for Power Compact Lights | timtalk | Electronic Projects Design/Ideas/Reviews | 7 | 28th August 2005 07:28 AM |
| Voltage controlled amplifier | Jimbo | Electronic Projects Design/Ideas/Reviews | 2 | 20th October 2003 12:24 PM |
