Old 13th May 2008, 10:29 AM   (permalink)
I think i was over complicating it.
So i use a non-inverting comparator which will give me a digital ouptut signal with the same polarity as the input signal. I then choose the correct feedback resistor to give which sets the limits.
I change the vref by changing the value of reisitor?
Thanks for your help
Lyallbay04 is offline
Old 13th May 2008, 10:56 AM   (permalink)
The blue text is correct.
The Vref is usually set by two resistors forming a potential divider from the +Vsupply to the 0V.
Its a good idea while you are testing, to add a variable resistor in series with two fixed resistors.
Something like this drawing.
REMEMBER: the LM324 OPA does not make a good comparator..
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 14th May 2008, 10:38 AM   (permalink)
Does this look better i had a bit of problem using my first set-up. Does this look better to you?
Old 14th May 2008, 12:04 PM   (permalink)
I have changed the value of the resistors, they were too low.
Also the 10K from Vref is not required, but I usually use a 470R.
Why have you deleted the Rh hysteresis set pot,??
Otherwise looks OK.
Eric
PIC tutorials:
Old 14th May 2008, 11:12 PM   (permalink)
Is the hysteresis set pot just a varaiable resistor to help set it??
Old 15th May 2008, 08:15 AM   (permalink)
Setting the required level of hysteresis and the upper/lower voltage limits using 'preferred values' of resistors can be tricky.
Problem is, when you change the Rh [fixed] resistor the Vref point moves, so you adjust the Vref and then the switching limits change...
I have found the easiest way is to calculate an approximate value of Rh and Vref,
then include in the Vref and the upper/lower hysteresis circuit, variable resistors.
The variable can be replaced for fixed resistors after you have determined the required fixed values.
[you measure the resistance values of the variable resistors]
Do you follow.?
Eric
PIC tutorials:
Help, Schmitt trigger rngd General Electronics Chat 22 25th February 2008 05:10 PM
Need help with Schmitt trigger application! whirlwindz General Electronics Chat 8 23rd May 2007 01:06 PM
PIC – RB0 Interrupt pin Schmitt Trigger input elexhobby Micro Controllers 5 9th October 2005 10:31 AM
Calculating Schmitt Trigger Wbdsgnr General Electronics Chat 1 29th March 2005 06:05 PM
diffferences between a TTL and a ST (Schmitt Trigger) I/O ?? foosm Micro Controllers 2 27th August 2003 07:27 PM
