| Can anyone tell me where I can get about 10-20 of these circuit board made cheaply? I think I would only need a 1 layer board correct? Obviously I don't need the existing circuits in the box... Thanks! | |
| What circuit board? That's more like a schematic than a layout. You could try express PCB for small orders like 10-20pcs. | |
| Don't really see the need of a PCB in the first place. Just solder a diode across each relay coil, the third goes in line. The rest is just wire. | |
| Hi, Yes Harvey, just what i was going to say. I looked at that for a bit, then thought that might as well be some connector block, or in a car perhaps one of those spade terminal block strips. I think you can get them with a plastic cover, (a bit like the old car fuse strips) If its done neatly it should look alright. John
__________________ ************************************************** *************** | |
| Looking at that circuit, the relays are automotive relays which have spade terminals on them anyway. Solder the diodes directly across the terminals as close to the base as you can then the rest just plug on (apart from one diode). | |
| Don't know about places!But for a commercial product it needs a board.otherwise customer wont satisfies. I'd simply do a silk screen including top layout & printing the boards.The silk frame I have & going to a shop to expose the artwork just only 1.5 US$. See the recent work of us did with my friend (pasan). | |
| Ah just now found. "Chemelec" a forum member of electro tech is doing this job.But he is not doing in large quantities. 20pcs is ideal for him. http://www3.telus.net/chemelec/pcb.htm Email is in his web site. | |
| CIRCUIT DOESN'T WORK | Russlk | General Electronics Chat | 14 | 25th November 2008 05:34 PM |
| Basic Soldering & Desoldering Guide | ElectroMaster | Electronic Theory | 15 | 13th November 2008 01:23 PM |
| Analog Meter | windozeuser | General Electronics Chat | 19 | 3rd October 2007 03:44 PM |
| Development board problems [was : Circuit Capacitance?] | Joel Rainville | General Electronics Chat | 14 | 15th September 2005 03:40 AM |
| Led cyclic dimmer/controller circuit? | yel-low | Electronic Projects Design/Ideas/Reviews | 13 | 9th August 2004 05:00 PM |
