Old 12th May 2008, 07:50 PM   (permalink)
Default 12VDC to 12VAC
I've got a electronic door lock which is powered from a 12VAC transformer. I would like to use a 12VDC backup battery to open the door in case of a power failure. What would be the best way to do this - do I need a 12VDC to 12VAC inverter, or is there an easier way to power the door lock off the battery?
gregmcc is offline   Reply With Quote
Old 13th May 2008, 01:11 AM   (permalink)
You can probably run the door lock straight from DC.
There might be more current, because the inductance of the coil won't affect the current with DC, but it will with AC.
If it is just a door release that only operates for a few seconds at a time, extra current probably won't hurt.
As a start, measure the current taken at 12V AC and at 12V DC
Diver300 is offline   Reply With Quote
Old 13th May 2008, 03:44 AM   (permalink)
You could add a resistor in series with the battery or use a lower voltage to make the DC current the same as the AC current.
crutschow is offline   Reply With Quote
Old 13th May 2008, 11:38 AM   (permalink)
thanks - I'll try that.
need help on 12VDC to 12VAC circuit DW1QRZ General Electronics Chat 13 2nd January 2008 11:09 PM
12vac to 12vdc gifford General Electronics Chat 11 18th July 2007 12:58 AM
12VDC battery to 12VAC inverter? Troy Jollimore Electronic Projects Design/Ideas/Reviews 4 7th June 2004 12:23 AM
How to Convert 12VDC to 12VAC? kevinloh Electronic Projects Design/Ideas/Reviews 3 28th October 2003 03:29 AM
12VDC to 12VAC Ricardo Electronic Projects Design/Ideas/Reviews 4 2nd October 2003 01:47 AM
