| Hi everyone, I found this site through google, I am trying to find 12VDC to 75VAC (50/60Hz) inverter, very low power (<5W). Can I find off-the-shelf? If not, is it easy to build one? I have tried to google to find one with no luck. Any help welcome. I live in the UK. Thanks, Pelle Last edited by pellepeloton; 12th May 2008 at 04:15 PM. | |
| If you find something, please come back and post it. I need the same thing for charging a big capacitor off a solar panel... My searches didn't bare fruit either. | |
| Apparently they needed high voltage circuit to run the old style telephone ringers like explained here http://www.sparkfun.com/commerce/present.php?p=High Voltage Ringer. | |
| You should be able to find low wattage (40W?) inverters, and then add aa 220 to 75v transforrmer. | |
Does the output have to 'square' or 'sine', also is the 50/60Hz essential.? What are you going to drive with the output.?
This would replace 230VAC transformer. I don't know if it has to be sine and 50/60Hz, but that's what the output is from the mains transformer. | ||
I have looked for low power 12Vdc convertors with no luck. As you dont know the requirement of the shower panel, its not easy to suggest a simple solution. The voltage of 75Vac sounds very unusual, where would the shower panel normally be plugged in.? does it come with a local mains to 75Vac transformer.?
| using a 320W flash with a 150W inverter | denoise | General Electronics Chat | 5 | 19th February 2006 04:44 PM |
| Help on desiging a Discrete inverter to replace 74HC04 | 8899 | General Electronics Chat | 22 | 17th October 2005 04:47 PM |
| Starting of SCR controlled 50KW Inverter (1KHz Frequency) | Riyazahmad | General Electronics Chat | 3 | 14th May 2005 10:02 PM |
| Where can I find a hex inverter? | saidias | Electronic Projects Design/Ideas/Reviews | 2 | 29th August 2003 05:31 AM |
| real simple problem, but I can't find the solution. | 1997 GA16DE | General Electronics Chat | 35 | 18th July 2003 05:25 AM |
